Wtb: Built motor (short block)
Old Dec 13, 2009 | 03:27 PM
Ekfreddy's Avatar
Default Wtb: Built motor (short block)
No B16's or LS
Only looking for B20 or b18c or b18c5
No super high compression
let me know what you have
thanks
freddy
Old Dec 13, 2009 | 04:07 PM
dschwantz's Avatar
Default Re: Wtb: Built motor (short block)
why wouldnt you want a ls?
Old Dec 14, 2009 | 11:07 AM
Ekfreddy's Avatar
ttt
Old Dec 14, 2009 | 03:50 PM
nate_2k5's Avatar
i have a block at the shop now that i no longer need, let me know if you are interested. it is
B18C1 Block, honed, decked, and align honed with ARP rod bolts
Shotpeened GSR rods with new USDM ITR Spec pistons from RS Machine
Golden Eagle Head Studs
ARP 9mm Rod Bolts
Fully Balanced Rotating Assembly
ACL Race Bearings
New ITR Oil Pump
no water pump or oil pan
it is disassembled with zero miles
Old Dec 14, 2009 | 04:04 PM
Crash88's Avatar
It would save you money to come up with a core of what ever motor you choose. Then send it to a shop to get resleeved . Also consider having the lower end built to your needs. Try Robert at sales@goldeneaglemfg.com
Old Dec 14, 2009 | 06:59 PM
Ekfreddy's Avatar
ARP 9mm Rod Bolts
ACL Race Bearings
New ITR Oil Pump
Pm a price
ttt
Old Dec 15, 2009 | 04:24 AM
TeamJDm_d's Avatar
bump for a great guy
Old Dec 15, 2009 | 05:24 AM
RyanA's Avatar
I may sell one of mine. It's currently still at the machine shop getting the block done.
B20B block
84.5 bore
RS Machines ITR replica pistons
Eagle H beam rods
Stock micropolished crank
Currently has no bearings or oil pump. If you want it assembled, I could put it all together using OEM Honda bearings and a new OBD2 oil pump. PM me if interested.
Old Dec 20, 2009 | 08:59 AM
Ekfreddy's Avatar
B20B block
84.5 bore
Eagle H beam rods
Sounds good i might take it with out the bearing and oil pump since i get Parts discounted thru honda
let me know what you looking to get for it
thanks
Old Dec 20, 2009 | 09:08 AM
built94dc2's Avatar
ok r u looking for a motor built for boost or all motor, also do just need the motor or tranny also let me know
Old Dec 20, 2009 | 09:44 AM
Ekfreddy's Avatar
All motor depends if u have a good head set up already and the price is right ill might get it also No Tranny i have several trannys
Old Dec 21, 2009 | 07:25 AM
Ekfreddy's Avatar
ttt
Old Dec 21, 2009 | 08:16 AM
Rtboy10's Avatar
check my thread maybe we can work something out
Old Dec 22, 2009 | 07:35 AM
Ekfreddy's Avatar
ttt
Old Dec 22, 2009 | 07:49 AM
kings**t's Avatar
http://www.hondamarketplace.com/show....php?t=2646248
try this i am willing to work something out
Old Dec 22, 2009 | 09:52 AM
Ekfreddy's Avatar
that alot of motor ill be honest your asking a great price but my budget is lower then that
thanks
Old Dec 22, 2009 | 12:09 PM
TallKyle's Avatar
Can i get my line wrench back? I needs it
Old Dec 28, 2009 | 09:28 AM
Ekfreddy's Avatar
i got you my bad
XxRoCkMaNxNEOxX
Texas -OK -LA (Sales)
Mar 15, 2014 06:40 AM
es.roadster
Northern California (Sales)
13
Aug 18, 2010 07:49 PM
JDM son!
Aug 13, 2009 06:05 AM
CRVTEC0WNZJ00
Oct 13, 2004 03:44 PM
