'94 Accord weird tranny problem HELP!!!
today i realized that it has become very hard to change gears. the car is a 94 accord auto tranny, when you try to go from "p" to "r" to "n" then "D" it feels like someone is pushing against the shift linkage making it extreamly difficult to put it in gear. while the car is in motion the tranny seems smooth.
also at freeway speeds there is a very loud howl .
is my tranny shot? or is this something else
also fluid level is good.
thanks for your help.
First check the brake switch, which may be causing the hard shifting of the lever out of Park, etc.
Problem may be a bad switch signal; may need to replace switch.
Are you sure the howl is coming from the transmission? The howl, may be a bad wheel bearing.
BTW: This is the 2003 -current Accord forum.
btw i just realized its in the wrong section...i was in the hurry to post the question
MODS: can you please move this...thanks.
DnB TeK
Oct 1, 2007 09:58 AM
fter out of park without sticking the key into the release slotHelp with automatic tranny problem (p
hybrid_KJ
Jan 23, 2003 09:56 AM
