CRX HF Project build
1988 Honda CRX HF
1.5L Sohc Non-Vtec D15B6 5speed trans.
Purchased for $100 from a friend in millwalkee wisconsin.
Orginally purchased from dealer in new york.
This is a project I've been waiting for I also to go with this car got a 1989 CRX Si shell for parts.
Here are some pics. I'll post more updates as things progress.
..Casey
..Casey
not sure. when I bought it the trans was taken out. I had to change the clutch and now it's not starting. the starter sounds as if it's engaging but... the engine won't crank. it ran when they brought the car in but then they pulled the trans out.
well it starts. now I'm just going to tighten up the suspension and begin the long body work process. Then I'm hoping I can swap the motor next summer. I'm thinking B series. possibly a B20 but I'm going to keep researching. I want to put the most power I can into the bay... but I also don't want to spend over a budget.. which I still have to figure that out... which is whats holding me up on things currently.
Update:
Black Si-R dashboard installed.
Si-R doors installed.
New Radiator installed.
Painted valve cover (blue anodized)
Removed sound deadening.
Began the wire tuck.
Removed rear stock suspension.
replaced rear drum brakes (now I have a parking brake that works.)
should have more done by this weekend.
update finally
But I'm waiting on my spindles to come back from getting new bearings and ball joints.
picked up the following..
CRV engine parts-
B20B block
P3F pistons
PR4 Rods
water pipe
other misc parts
19T water pump and oil pump
oil pan, pick-up and baffle
garrett T25 Turbo and misc parts.
GSR timing kit with 22t water pump and head gasket kit
slim cooling fan
99 civic si radiator and cap
prelude seats.. black and fresh.
will post up some pics this weekend.. camera has to charge.
CRV engine parts-
B20B block
P3F pistons
PR4 Rods
water pipe
other misc parts
slim cooling fan
