clock spring installation
Old Dec 13, 2009 | 06:48 AM
punkinbeck's Avatar
Default clock spring installation
I tried searching. Gave up. Is there a write up on a clock spring install on here? I put in a used one months ago then it went bad. I wasn't sure if it was just junk or i was an idiot and put it in wrong. I bought annother one I want to make sure i'm installing it right before I put it in.
Old Dec 13, 2009 | 07:23 AM
spoolinNpullin's Avatar
Default Re: clock spring installation
just count it from side to side, go real slow and spin it untill you feel some resistance, once you feel the slight resistance then stop and spin in the opposite diriection and count how many turns untill you feel slight resistance, once you feel the resistance and you have counted then just split that in half and that is your center, I have used this method for about 10 years at my shop and it has never failed me. also if you do not ever feel any resistance than the ribbon inside is broken from someone spinning it to much and breaking the ribbon
Old Dec 13, 2009 | 08:58 AM
punkinbeck's Avatar
thanks a million
Old Dec 13, 2009 | 10:08 AM
Anon51's Avatar
x2 i'v done this aswell but only for used clock springs. since new ones come with a break-off tab thats already centered.
RustyE.G.
Suspension & Brakes
May 19, 2010 03:43 PM
jrivehard
Suspension & Brakes
22
Dec 16, 2008 09:26 PM
alscrx
Honda Civic (2001 - 2005)
Mar 25, 2008 07:09 PM
Beach Accord
Oct 18, 2004 03:09 PM
joelsolers
Aug 17, 2001 09:53 AM
