Accord 2001 wont start and stalls
Hi Guys
Need some advise please.My car does not start especially when cold. The engine management light and the green key light do not come on when it has starting issues, but when these two lights come on and off the car starts fine and drive. It also cust out whilst driving.
What I have done so far:
Changed main relay- no change
changed ignition switch- no change
changed battery- no change
got all connect uner dash checked for loose connections- no problems
Checked the engine management system. it records the following faults
P0700,P0763,P1753
A frined of mine told me that all three of the above still indicates ignition switch issue? is this correct.
My auto box is fine changes through the gears just fine no issue. Surely these faults cannot cause the car to stall and not start? Please advise
Thanks
Sam
P0700,P0763,P1753
Thanks
Sam
from this link...
http://www.6thgenaccord.com/forums/s...t=p0700#post39
it says the codes youre getting are related to the auto trans.
just scroll down, and youll see that the p0700 code is highlighted red, and the rest of the codes youre getting are in that line as well. maybe it could be your trans solenoid, idk though.
pacdecimal
Jul 4, 2014 05:34 AM
sam786
Jan 1, 2010 10:53 AM
