It is require to change automatic belt tension...?????
Old Dec 12, 2009 | 07:49 PM
black94lude's Avatar
Default It is require to change automatic belt tension...?????
Hey guys, Im about to change my timing belt in my lude. And I want you guys opinions...............it is require to change the automatic belt tension as well or can I still used my old auto belt tension...............???????????????????????????? ?????? Any advices and suggestions is appreciate..................thanks...........
Old Dec 12, 2009 | 07:59 PM
Matt55's Avatar
Default Re: It is require to change automatic belt tension...?????
you mean the tensioner? JUST SPELL IT OUT MAN! but yea you might as well change it
Old Dec 13, 2009 | 07:04 AM
313hitman's Avatar
those things are known to fail that why alot of people switch it to manual tensioner.
Old Dec 13, 2009 | 03:11 PM
TheJGB3's Avatar
Actually that was only with the 97 & 98 models. The part was 'superceded' for the 99-01 model years. The superceded part is an improved design which wasn't prone to failure as the earlier ones on the 97 & 98s. It is recommended that the tensioner be changed with the timing & balance belts just like the water pump is because the belts have to come off to change them anyway 'preventive maintenance'.
Old Dec 13, 2009 | 09:00 PM
Thanks for the suggestion and advices guys.......What kind of parts do I need to have in order for me to convert from auto to maual belt tensioner..........???????? Any suggestions........Thanks.........
zoopreme
Jan 4, 2010 06:31 AM
chahsiubow
Dec 14, 2007 10:01 PM
petrv
May 10, 2006 03:24 AM
civickiller
Feb 26, 2004 10:02 PM
Bigjussin
Nov 10, 2003 06:06 PM
