Axles in my B16a2 swapped EG
Im finishing up this swap project and was trying to use my oem 99 civic si axles in my eg. I tried bolting up the hub ( also off the si ) and it feels like the axles are too long since i cant get the lower and upper ball joints bolted in at the same time. It also did this with the stock EG hub. Im guessing i need to get different axles but which ones? and the rear disc conversion from si will fit onto the EG, correct? Thanks in advance.
