Bouncing Tach needle
Old Sep 2, 2002 | 06:49 PM
raceboy71's Avatar
Default Bouncing Tach needle
I have a 90 civic si with 120,000 miles, and there seems to be a problem with the tach needle. When the car first starts, the car heitates alot, and the tach needle bounces around like crazy. The dealership has looked at it, but they came up with nothing. Once the car is warm, it settles down a bit, but at 3500 and up, it still bounces, and there it feels like a misfire when I push the revs to 4500 plus. If anyone has experienced this, or has an idea or two, let me know. The car is perfect other than that, and I love driving it. Thanks.
Old Sep 2, 2002 | 11:13 PM
ThatRicerDaniel's Avatar
Default Re: Bouncing Tach needle (mfaigaux)
distributor ~ eventually it will go out ~ you could probly just replace the igniter and get a little more use out of it but its better just to replace the whole distributor assembly now .. about 170 from kragen after core.
Old Sep 3, 2002 | 06:11 AM
SuperCivic's Avatar
definately ignitor. common problem, easy fix.
Old Sep 3, 2002 | 08:49 AM
crxhfpower123's Avatar
there maybe a bad ground if the ignitor is bad check the ground that goes to the block if it isnt on a good spot it will make **** like that happen
Old Sep 3, 2002 | 12:04 PM
VELOCITY R's Avatar
Ignitor! $90.
Old Sep 3, 2002 | 01:09 PM
raceboy71's Avatar
thanks for the help.. I had the Ignitor replaced about 6K miles ago, but maybe it was a bad ignitor. I'll check the ground, and once again, thanks.
Old Sep 3, 2002 | 02:33 PM
NikoZai's Avatar
yeap, igniter, same **** happened to my b16a1 (no replacement distributror available) luckily it turned out to be thhe igniters ground so both the unit and distributor were fine. Check that a few times before you spend $$$, especially since you say you changed it 6k ago.
cheek32
Jun 27, 2011 06:24 PM
hondacivic90zc
12
Jul 3, 2009 08:57 AM
Apd3111
Jan 4, 2006 02:45 PM
De_tour
Dec 15, 2005 06:59 PM
WhiteEG6
May 20, 2004 03:57 AM
