rsx issues
Old Dec 12, 2009 | 06:39 AM
bj1987's Avatar
New User
Default rsx issues
the other night i was drivin and all my gauges started flashing and my power steering went out. i pulled over and turned my car off then turned it back on and it was fine. what the hell did it do that for?
Old Dec 12, 2009 | 09:59 AM
turboteg2nv's Avatar
Default Re: rsx issues
Sounds like a short in your electrical system.
Check all the grounding points.
Old Dec 12, 2009 | 02:46 PM
kobeballer96's Avatar
^ sounds more like a way to kill a clunker. dont be a smart *** he was just looking for clues
Old Dec 13, 2009 | 01:14 PM
sicky's Avatar
grammer nawzi
Originally Posted by ap1 george
I know what your problem is..Here's what you do
1. Drain your oil
2. Put saw dust in your motor
3. Rev the motor to 9k
4. Hold it for 30 minutes
5. Disconnect the negative battery ( this should reset your ECU)
Follow these steps and you're good to go
Get this kind of **** out of here.
After looking at your other posts on this site, it is evident that you are a troll, and you will be banned shortly. Hope you enjoyed your stay, and **** off.
Old Dec 13, 2009 | 01:46 PM
sirb16a's Avatar
it could have just been a surge nothing serious id say check all electrical plugs under the hood too make sure they arnt wet then wait to see if it ever happens again it happened to me to but its been like a year now and it hasnt happened again..its just a relay that probably got stuck for a second thats all.....good luck
Old Dec 13, 2009 | 02:30 PM
mustclime's Avatar
check you drive belt ......rsx has a pwoer steering pump and should not be effected by a power surge and alike....when belts get old, they can get wet and the crank pulley will just spin on them...when this happens you loose power steering and the alt is not charging so the light will dim....I have a blower and I go through a belt every 8 month to a year, regular cars can need belts changed ever 2 -4 years depending on milage,where you live and what you drive through. If you live in a road salt area, a lot of tat sand can get cought up in the belt and reduce its grip.
roni_xxp
Engine Management and Tuning
Apr 12, 2009 05:04 PM
crx2fast
Apr 7, 2005 01:20 PM
vg30dett71510
19
Dec 1, 2003 09:05 AM
Red00SI
Apr 1, 2002 03:51 PM
tampaSi
Oct 13, 2001 11:36 PM
