heat stopped working
the other day my blower motor decided to poop out on me. it just stopped working alltogether it seemed like there was no problem the days prior and just stopped. is there a fuse for the blower motor, and what amp and what #fuse would it be under the dash?
well, if you pull the fuse box cover off, it tells you EXACTLY which fuse it is..
you could always just pull each fuse out and check.. its not as tedious as it sounds..
But yeah.. just start actually looking for blown fuses.. im sure you will probably find one for the blower motor
ah.. lol.. ummmm.. just pull them one by one and look at them.. you should be able to see a break in the fuse if its bad..
check the ones under the hood, too.. lol
exactly thank you! i found out there was a 15 amp fuse instead of the 30 that should be there for the heater motor. now my batteries dead so now i cant see if it worked...
well was that 15 amp fuse blown or was it fine.. cuz if it was fine changin it to the 30amp isn't jus gonna make it work... My blower motor and radio stopped workin couple weeks ago at the same time and i checked all fuses and power n ground .. turned out to be a bad ignition switch cuz the radio worked while the key was in the acc position but not when running. so keep that in mind too.
ExtraBlackRex
Dec 16, 2010 03:27 PM
Mishima
Jun 30, 2009 09:08 PM
si0385.
20
Apr 17, 2006 08:12 AM
