Function 7 LCA Spherical Bearings
Old Dec 11, 2009 | 02:17 PM
tweek_boii's Avatar
Default Function 7 LCA Spherical Bearings
Do they squeak after months ???
Old Dec 11, 2009 | 02:33 PM
prejdmlude's Avatar
Default Re: Function 7 LCA Spherical Bearings
y not call F7 and ask them. they have hooked me up with some of the problems i had with mine.
Old Dec 12, 2009 | 11:27 AM
tweek_boii's Avatar
What kind of problems?
A company isn't going to be as honest as a customer that already has them
Old Dec 12, 2009 | 01:07 PM
prejdmlude's Avatar
on my lca the hole for where the larger bolt for tie brace was to small and so was the spacer so it was a pain in the *** to get one side in have to sets so i just called them up and said since i bought from them they warrantied it.
Old Dec 12, 2009 | 05:22 PM
mustclime's Avatar
I had spherical bearings on a track day rabbit gti.....After every rain it sounded like a pack of very upset mice going down the road....no idea if function 7 will do the same.....
Old Dec 13, 2009 | 08:23 AM
E-Money's Avatar
You want these for daily driving?
Old Dec 13, 2009 | 03:17 PM
tweek_boii's Avatar
Yes this would be for daily driving, going along with a progress tie bar
Old Dec 25, 2009 | 01:27 AM
Cnile1's Avatar
Whats the advantage of having the spherical bearing as opposed to the regular bushing?
As a daily driver I would be concerned about road salt and other things damaging the bearing. But as a track car, I would think the suspension would be alot stiffer. Also look out for counterfeit function 7 parts. The website warns people about it on this page function7 .com/warning .
Old Feb 3, 2010 | 09:43 AM
Function7's Avatar
Unfortunately the spherical bearings are a wear item and will be noisier as they wear down. However the spherical bearings are teflon lined so they will not squeak, but as they wear down there will be more road noise.
The spherical bearing arms are intended for "no compromise" race cars and not for daily driving in harsh environments (i.e. heavy winters/salted roads etc).
Like all our products our spherical bearing arms are designed to be field replaceable (e.g. if you're out on the track and need to replace parts) so if they do wear out, new spherical bearings can be dropped in very easily. The spherical bearings are standard aerospace-grade components so they will always be available.
That said, we do provide a 3-year warranty on our spherical bearings, but the rest of the arm is covered by our standard lifetime warranty.
=A
Old Feb 3, 2010 | 01:01 PM
turboteg2nv's Avatar
Glad to see the response from F7
Old Feb 3, 2010 | 03:19 PM
square_1's Avatar
Yeah. I would not put those things on a daily driver. Going to be very rough and bumpy ride! There could be times your girlfriend might like it a little though.
Old Nov 16, 2012 | 04:05 PM
nextproject97's Avatar
Back from the dead a 2 year old thread !! I am looking into function 7 s my car is mostly a track car with occasional street driving but very little .Who has run the function 7 s with or without the spherical bearings that can give some input on weather or not to go with the spherical bearings or not .They both list as being for extreme use any input is appreciated !
Old Nov 17, 2012 | 07:53 PM
doood's Avatar
been there done that
i have them with regular bushings on my daily. going on well over a year and no unusual noises, squeaks, etc.
Old Nov 18, 2012 | 10:33 AM
Thanks I definitely don't want any squeak, squeak **** goin on ! Do you track it at all ? Are you putting down big power and driving it hard ?? Both of their lcas are listed for extreme duty .I am leaning toward the spherical brngs as I don't daily it but they are more expensive I drive hard and track the car often .I appreciate your input and anyone else who can chime in please do share your experience with the function 7 s
Old Nov 18, 2012 | 11:31 AM
doood's Avatar
the only track it sees is the drag strip. i drive it hard on the street and put a lot of miles on it.
solex
Honda Civic (2001 - 2005)
Mar 24, 2017 10:58 AM
thegatekeeper14
Suspension & Brakes
Jan 3, 2013 05:48 AM
rextasy
May 14, 2007 10:19 AM
91SiKen
Jun 11, 2002 07:21 PM
albert butterbikini
Feb 21, 2002 12:31 PM
