Civic Light Problems??
well i just got a bone stock 94 civic ex,it had side markers but they wernt hooked up. well we hooked everthing up and everthing worked fine blinkers, turn signals etc. i went to put the drivers side corner light back in and hooked it up and when i did i cut the lights back on and nothing worked but the headlights, no brake lights, running lights and the corners didnt work. the blinkers work on the passanger side and thats it. when you turn the headlights on and the corners dont come on nor do the taillights? i went back to stock without the sidemarkers and still doesnt work now. is there a fuse or relay that controls all this? any help would be great. thanks guys
yea a couple times, its gotta be a relay or something. well i just messed with it and when you turn the left turn signal on, the clock and climate control blinks with the blinker?? im stumped
idk ok on the passenger side all the turn signals work including the side marker, and then on the drivers side all the blinkers work except the sidemarker?? but still no tail lights or brake lights. and the corners only come on when you use the blinker but not when the headlights are on??
jacksonww
May 28, 2008 08:29 AM
mister_r0b
Jul 16, 2004 10:42 AM
