crx b16 obd0 header
Old Dec 11, 2009 | 08:03 AM
hondaex99's Avatar
Default crx b16 obd0 header
hey guys i just got done with my b16 swap and question is i wanna get a header for it because mine is rusted bad lol and its has the 2 o2 sensors and the ones they have on ebay.. has 1 am i going to have to make another o2 plug in and where would i put it at... i dont want the check engine light on lol
Old Dec 11, 2009 | 09:43 AM
0ne-Cam's Avatar
Default Re: crx b16 obd0 header
http://www.hondamarketplace.com/show....php?t=2642361
Old Dec 11, 2009 | 11:06 AM
gringo7718's Avatar
You need to weld O2 bungs here. Each O2 monitors 2 cylinders and needs to be close to the head to keep them hot enough to work properly.
HAsport obd-0 header
Old Dec 11, 2009 | 05:52 PM
sgallagher's Avatar
^^This is correct
If you do not have your O2 sensors in the correct location your engine will NOT run correctly.
Old Dec 12, 2009 | 02:07 PM
zrickety's Avatar
the one that you speak of is near the cat, right? you can't use it for obd0. you'll need to plug it and make 2 openings like shown above. or upgrade to obd1 and then use that one spot. or don't hook up the o2 at all...it will run fine, just a little rich, no check engine light
atmdc
Sep 15, 2008 10:07 PM
crxpwr1
13
Nov 26, 2007 12:29 PM
redrusch
Aug 29, 2007 08:44 AM
OBHATCH
Sep 8, 2006 11:30 AM
CRX MASE
Jun 16, 2006 06:19 AM
