CRX STRUT replacements
Old Dec 11, 2009 | 06:35 AM
krob's Avatar
Default CRX STRUT replacements
I hear a knocking sound on bumpy roads and am thinking I need to replace all way around. Sort of restoring my 91 crx si with 100k anyhow but would like a suggestion on replacements and the process to do it. I have spring compressor but just have not actually ever replaced struts. Can someone lay out the steps.. I am not looking to lower the car. It runs and handles pretty well as is.. I had rather see it set up similar to maybe a rally type car anyhow. My daily driver...
Old Dec 11, 2009 | 06:49 AM
guitarguru87's Avatar
Default Re: CRX STRUT replacements
Replacing the struts is definitely not hard. If I remember right just remove the wheel, compress the spring, unbolt and remove the strut/spring and reverse for installation. If you want a stiffer ride and you have $ go for the koni yellows. If not then koni reds, tokico blues, and kyb gr-2s are good as well, especially since you are not lowering. Word of advice, wd-40 the hell out of the strut bolts before you try to remove them. I broke both rear ones and had a hell of a time getting them out.
Old Dec 11, 2009 | 10:45 AM
elf469's Avatar
while you're at it, look into replacing the strut/shock mounts too. if they need it of course.
Old Dec 11, 2009 | 10:59 AM
gringo7718's Avatar
Here is a writeup for a newer civic but they are very similar. It should give you a really good idea of what you have to do.
http://www.civicforums.com/forums/44...info-pics.html
Old Dec 11, 2009 | 12:23 PM
BiG ChOr!Zo's Avatar
http://ef-honda.com/ben/EFlowering.php
Old Dec 11, 2009 | 06:23 PM
jhammond_82's Avatar
Reject Papi
i don't even use a spring compressor, lol. just unbolt the fork, unbolt the top two nuts in the engine bay, and wala! then use the allen wrench, and wrench, and take the top off. then reverse with new strut. its cake.
88turdbucket
Suspension & Brakes
Feb 17, 2006 05:40 PM
EF9 JAMS!!!
18
Jun 6, 2005 08:54 PM
