idle issue
Old Dec 11, 2009 | 05:18 AM
00EckoSI's Avatar
Default idle issue
I just installed a new exhaust from the header back with a test pipe and cat back...i reset my ecu because the check engine light came on when i moved the car with just the header on and when i drove it to my buddys shop (about40 miles) on an open header...now that i have everything on and reset the car at idle fluctuates from 1k to 2k and drops back to 1k and back up to 2k and keeps doing this...no CEL or any other issue..Any ideas..2000 Honda Civic si no swap still a b16a2
Old Dec 11, 2009 | 07:15 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: idle issue
iacv? ficv? clean them and then try it.
check for vacuum leaks...
did you throw out an o2 sensor?
Old Dec 11, 2009 | 09:03 AM
00EckoSI's Avatar
nope reused the second one replace the first one
Old Dec 11, 2009 | 09:15 AM
I'm not Rick!
clean your iacv or get a new one and clean the ficv under the TB.
thewrai6th
Apr 29, 2014 12:59 PM
00EckoSI
Dec 12, 2009 10:38 PM
91highryda
Sep 26, 2007 04:58 PM
