Front Lower Tie bar..
Hey, I was thinking about purchasing a rear lower tie bar, and front lower tie bar. What I'm confused about is where does the Front lower tie bar attach to? The front lower control arms? The reason I'm wondering this is I was reading some where about people having take out exhaust and shift linkage, and is the front LCA an allignment arm?
I know installing rear lower tie bar would be simple its just two bolts in the back. Anyone know what has to be done to install front lower tie bar, in an EK hatch?
thanks.
thanks.
The front bar attaches to the inboard mounting points of your front lower control arm. It goes underneath your header and many aren't compatible with 3" downpipes and K swap headers because of clearance.
The front lower control arms are not alignment arms. They are non-adjustable and if you install a front lower tie bar you won't need to get your car aligned.
