Windshield washer fluid hose broke now fluttering with no power
Old Dec 10, 2009 | 10:13 PM
samba_green_sol's Avatar
Default Windshield washer fluid hose broke now fluttering with no power
i filled up my washer reservoir tonight when i got off work, then when i was leaving i hit the sprayer so it would wash some **** off my windshield then about 5 seconds later it lost all power and was stuttering really bad and the car was shaking violently when stopped, so I pulled over and popped the hood and there was washer fluid everywhere because one of the hoses broke.
I let it idle for probably 20 minutes hoping whatever it was that got wet would dry out, but the only thing i could see that got wet was the top of the injectors I got those dried out as good as i could when it was pitch black outside and 22 degrees.
Should I just take the connectors off the injectors in the morning and leave it sitting for a while and hope that it dries out good enough?, or is there a possibility that I shorted an injector and need to replace it, and is there anyway to test an injector?.
Thanks
Old Dec 11, 2009 | 05:52 AM
honda.lioness's Avatar
Default Re: Windshield washer fluid hose broke now fluttering with no power
I would be wondering whether your Civic's alternator got soaked and so this was the cause of the problem. Hopefully the alternator dried out.
Old Dec 11, 2009 | 05:58 AM
crazycornuts's Avatar
Check your plugs as well if water gets in the plugs it will make them miss
Old Dec 11, 2009 | 07:02 AM
97twodoor's Avatar
More specifically the spark plug wires. Plugs cant really get wet cause the plug wires go over top and seal them.
knightnam
Aug 16, 2006 10:44 AM
Thunder Cat
Dec 9, 2005 03:39 AM
dudefella
Nov 4, 2005 10:21 AM
Stebo77
Jul 10, 2003 09:08 AM
Tr0LL
Jan 29, 2002 02:14 PM
