Ignition System
Old Dec 10, 2009 | 08:43 PM
petermartin's Avatar
New User
Default Ignition System
Hello !!
Automobile Ignition System constitute of various devices, tools and components that are used for igniting the fuel in an internal combustion engine of a vehicle. In this system, electric current is used for burning the mixture of air and fuel with the help of coil, battery, and spark plug.
Ignition system is assembled in only those automobile engines, which operates with the help of petrol or gasoline. The two main functions of automobile ignition system are to produce enough voltage so that it can easily create a spark for burning air/fuel mixture and secondly it exercises control over the timing of spark and transmit it to the apt cylinder. A typical automobile ignition system produces voltage somewhere between 20000 volts and 50000 volts from a 12-volt source. Automobile ignition system can be further classified into three main heads such as mechanical ignition system, electronic ignition system and distributorless ignition system. Most of the vehicles today incorporate electronic ignition system in its engine.
Thank You
Old Dec 10, 2009 | 09:47 PM
seanbev24's Avatar
Default Re: Ignition System
wtf?
Old Dec 10, 2009 | 09:49 PM
jdm inc's Avatar
Originally Posted by seanbev24
wtf?
x2
Old Dec 10, 2009 | 09:58 PM
Scott_Tucker's Avatar
No, thank you! You may now exit the building with much vigor.
Old Dec 11, 2009 | 07:59 AM
delsolproblems's Avatar
I think he expects a sticky, so future generations will know the quasi-literate definition of an ignition system.
Oh, and Peter.....you're welcome.
jacky599r
Jan 16, 2006 04:40 AM
JONBLAZE55555
Sep 10, 2003 05:27 PM
billk2k
Nov 4, 2002 10:44 AM
AJ PwR
Sep 26, 2001 03:16 PM
