Suspension & Brakes Theory, alignment, spring rates....
coilover setup
Old Dec 10, 2009 | 08:16 PM
93HondaDelSolSi's Avatar
Default coilover setup
I was wondering what type of coil over set up I should run. I am looking for a decent ride but with my current ride height. A friend of mine suggested either Tein or JIC. Suggestions are much appreciated. Here is a higher than stock, so I lowered both front and rear evenly.The car came with and has on it currently coil over spring sleeves, springs and on stock struts. I will post a pic in the morning so you can see current ride height.
Old Dec 10, 2009 | 08:22 PM
1.5Slowmatic's Avatar
Default Re: coilover setup
whats your budget is the first thing you need to ask than go from there. and whats your current ride height
Old Dec 12, 2009 | 06:02 PM
I found a set of Tokicos. http://raceinspired.com/p-6745-tokic...1993-1994.aspx. I was also looking at Tien Basics. http://raceinspired.com/p-2487-tein-...1993-1997.aspx
Old Dec 12, 2009 | 07:26 PM
.Manny.'s Avatar
Touching My Member
for that range, Koni/GC with custom rates tailored to your needs
Old Dec 12, 2009 | 08:32 PM
I am actually looking for a full kit, not just a set of decent shocks with coilover sleeves. This is also my daily driver.
Old Dec 12, 2009 | 08:43 PM
.Manny.'s Avatar
Touching My Member
ok.
Old Dec 12, 2009 | 09:11 PM
dandaman15's Avatar
Community Builder
You can get pic apex's in 8k/6k, they are the best budget full coilover.
Whydid
May 18, 2015 03:26 PM
Vomit
Suspension & Brakes
Jan 12, 2014 06:38 PM
Freshdot
Suspension & Brakes
16
Mar 28, 2013 12:04 PM
Mike_C
Suspension & Brakes
10
Jan 22, 2010 08:15 PM
perpetualburn
72
May 9, 2007 05:09 PM
