Wierd car not Firing/starting problems????????
Ok here is the deal, 91 crx si, 98 y8 motor with ~38k miles on it. Blown90Hatch, all connections are soldered and heat shrink wrapped. Running off a p28 ecu.
Every once in a while I will hop in my car and try to start the car, the starter will turn over and the motor will turn over but will not fire. If i tap the gas it will fire once and then nothing....... This usually happens when I am leaving for work so i dont have time to yank a plug wire and check for spark/fuel etc........ I get home from work about 9-10 hrs later and hop in and she fires right away.
I just replaced the plugs/wires/dist cap/rotor so we will see if that could be a problem.
It seems like the problem only happens when its really hot in the middle of the day ~4pm.
Could something be getting too hot and not wanting to start, with the humidity, it has been over 100 on any given day the past few weeks. ????
Thanks in advance.
Steven
Thanks in advance.
Steven
crexer
19
Feb 26, 2005 01:33 PM
cbrman
10
Oct 16, 2002 07:10 PM
