anyone got wiring diagrams?
Old Sep 2, 2002 | 05:04 PM
exr_pd's Avatar
Default anyone got wiring diagrams?
i need a wiring diagram for a 90 teg gs. does anyone have one or know where i can find one?
when i say wiring diagram, i mean which color wires do i splice into when installing my alarm.
thanks!!
Old Sep 2, 2002 | 07:56 PM
kwhitelaw's Avatar
Default Re: anyone got wiring diagrams? (teg_pd)
YEAR: 1990 MAKE: Acura MODEL: Integra STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white or wht/blk | + |ign harness or fusebox |
| STARTER |black/white | + |ign harness or fusebox |
| IGNITION |black/yellow | + |ign harness or fusebox |
| SECOND IGNITION |blue/white | + |ign harness or fusebox |
| ACCESSORY |yellow | + |ign harness or fusebox |
| POWER LOCK |green/white | - |either kick panel *1 |
| POWER UNLOCK |green/red | - |same |
| PARKING LIGHTS + |red/green | |steering column |
| HEADLIGHTS |red/yellow | + |steering column |
| DOOR TRIGGER |green/red *2 | - |dr kick panel/fusebox |
| DOME SUPERVISION |use door trigger | | |
| TRUNK/HATCH PIN |green/black | - |dr kick panel/fusebox |
| TRUNK/HATCH RELEASE |manual | | |
| TACHOMETER |blue | |distributor |
| SPEED SENSE |yellow/red | |instrument cluster |
| BRAKE WIRE |green/white | + |brake pedal switch |
| HORN TRIGGER |blue/red *3 | - |steering column |
| WIPERS |blue and blu/yel | - |at switch |
| LF WINDOW UP/DOWN |red/blu - red/yel | A |in drivers door |
| RF WINDOW UP/DOWN |blu/grn - blu/yel | A |in drivers door or dkp |
| LR WINDOW UP/DOWN |green - grn/yel | A |in drivers door or dkp |
| RR WINDOW UP/DOWN |yel/grn - yellow | A |in drivers door or dkp |
| RADIO 12V |white/blue | + |radio |
| RADIO GROUND |black | - |radio |
| RADIO SWITCH |yellow/red | + |radio |
| RADIO ILLUMINATE |red/black | + |radio |
| POWER ANTENNA |yellow/white | + |radio |
| LF SPEAKER |blu/grn - gry/blk | |radio |
| RF SPEAKER |red/grn - brn/blk | |radio |
| LR SPEAKER |blu/yel - gry/wht | |radio |
| RR SPEAKER |red/yel - brn/wht | |radio |
NOTES:
*1 Easier to locate at passenger kick panel. On drivers side, wires are
located high in kick panel.
*2 Looks like a 14 awg wire, but is mostly insulation.
*3 This wire is high current negative, MUST use relay.
(c) 1994-2002 Directed Electronics, Inc. All Rights Reserved
IMPORTANT: This wiring information is being provided free of charge on
an "AS IS" basis, without any representation or warranty. It is your
responsibility to verify any circuit before interfacing with it using
a digital multimeter. Directed Electronics, Inc. assumes no responsibility
with regards to the accuracy or currency of this information. Proper
installation in every case is and remains the responsibility of the
installer. DEI assumes no liability or responsibility resulting from an
improper installation, even in reliance upon this information.
Old Sep 25, 2011 | 05:54 PM
acuratuner1981's Avatar
i need a diagram on what color wires there are 6 that plug in the back of the ac/heat fan speed switch control its a turn **** setup on my 93 acura integra can someone please help it is suppose to have a wire connector block already pinned but i had to cut that off now i have no clue which wires pin on which connectors. theres 6 wires a dark blue one a black one a green one a blue/yellow, a blue/silver and a blue/white one. i know where the solid blue and the black ones go but no clue on the other 4. please help
Old Sep 27, 2011 | 06:25 PM
fcm's Avatar
fcm
Old Fart
http://www.bulldogsecurity.com/diagr...395&MakeID=113 94
Old Sep 27, 2011 | 06:37 PM
fcm's Avatar
fcm
Old Fart
That will be hard as I do not have a pic of the plug, however, if you have some time you can figure it out....
The black is the ground input to the switch, the rest are outputs.
Green is ground out to A/C switch it is a ground when blower switch is in any position except off.
Blue is ground out, speed one (1)
Blue/white is ground out, speed two (2)
Blue/yellow is ground out, speed three, (3)
Blue/black is ground out, speed four (4)
As long as you know where the black one goes all you need to do is turn the switch on to the 4 speed settings testing the pins as you go, the pin that tests as ground in all positions except off is for the green lead, switch to speed one and find the pin that is grounded connect the blue to it, switch to speed two and find the pin that is grounded and connect the blue/white to it and so on and so on. 94
TwoFaced
Dec 16, 2010 05:34 PM
DA1
Audio / Security / Video
Jan 12, 2006 11:44 PM
importzx
Dec 8, 2004 08:17 PM
InTeGrA B18b1
Dec 30, 2003 03:36 PM
sanders711
Oct 12, 2002 10:28 PM
