EP3 VS RSX TYPE S FRONT LCA
From: where i stunt SAND CANYON in Southern California
Hey people i need a new front driver side lower control arm and i wanted to know if the rsx type s lower control arms are the same as the ep3.. if anyone can give me more info please thanks !
the 02-04 are the same(stiffer bushings)....the 05-06 type-s will not work, the hole for the lower balljoint is larger. 05-06 type-s got type-r sized lower balljoints.
just a fyi....if you want to spend some time on this site...
http://www.acuraoemparts.com/delray/jsp/home.jsp
just compare part numbers...if the part numbers are different, the parts are different.
