PIC REQUEST: EK Sedan Sideskirt On A EK Hatch/Coupe
ok so after doing some searching and some measuring ive come to the conclusion that all EK sideskirts are the same length, BUT the sedan sideskirts dont flare out AS MUCH as the coupe/hatches do in the rear. so what i would like to see is a pic of ek sedan sideskirts on a coupe/hatch please!
i found a sedan at a local junkyard with sideskirts but i am hesitant to purchase them because i want to see how they will fit first, so any pics would be appreciated
They are the exact same length, but only the very first and very last clips on the coupe/hatch & sedan are the same. The 6 or 7 of them in the middle do not match up. The other difference is that the sedan side skirts have a 'top' that extends further down to cover the 'top' where the back doors are. When I put coupe side skirts on my sedan with the back door open you could see into them from above because that's after where the coupe door had already ended, so you might have to cut that part of them to make sedan side skirts fit on a coupe/hatch. The first and last clip is enough to hold it, and the part you might have to cut off will never be seen. Seems like too much work for such a minor unnoticeable change IMO.
cticknor666
Apr 19, 2010 04:12 PM
2ohSickness
36
Dec 4, 2009 10:25 PM
Slow Ek
Aug 5, 2008 08:26 PM
