rpm and speedo don't work...
Old Dec 9, 2009 | 01:57 PM
Clash0901's Avatar
Default rpm and speedo don't work...
i have a 91 crx si cluster and the tach and speedo dont work.
the motor is swapped to a b series. the speedo cable is plugged in, im confused as to why it doesnt work...
Old Dec 9, 2009 | 06:27 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: rpm and speedo don't work...
Is it pushed in all the way? Have you checked the back of the cluser as well?
Old Dec 9, 2009 | 08:13 PM
hatchet_honda's Avatar
well tach and speedo are 2 diff things...tach is elctrical and since you still have an si cluster then your speedo is cable driven. is the speedo cable in the vss on the trans? that lil clip come out?? take a looksee
Old Dec 10, 2009 | 08:51 AM
Clash0901's Avatar
that little clip is in-existent lol. i pushed it in all the way tho and tried moving a little and get no response tho, is the clip really all that necessary? even to just test and see if it works?
Old Dec 10, 2009 | 09:08 AM
4drEF's Avatar
Keyboard Humorist
Pull the cable out of the tranny (since the clip is nonexistent) and have somebody sit in the car and look at the speedo. Spin the cable by hand and they should see the speedo needle jump.
If it doesn't jump then either the cable isn't plugged into the back of the cluster properly or the cable is snapped.
When you figure out what the deal is with the cable then you really should use a clip - the cable has a way of working it's way out of the tranny. You can use a small paperclip or solid wire to make your own.
If the speedo still doesn't work after you tested it by hand and have put it into the tranny properly with clip then you'll need to pull the gear drive out of the tranny and see what condition it's in.
Old Dec 10, 2009 | 05:09 PM
dullboy01's Avatar
Had this problem about a year ago on my h22 91 accord and it was my speed sensor. Good Luck
88EFsedan2
Feb 2, 2012 08:24 AM
Gawear
Jun 19, 2010 08:22 AM
turbo-crx
Oct 20, 2008 12:05 PM
gsxr1k05
Sep 3, 2006 10:52 PM
civic889802
Jan 16, 2006 11:46 AM
