94 accord misfire
Old Dec 9, 2009 | 08:28 AM
ef-hatchcrap's Avatar
Default 94 accord misfire
My wife has a 94 accord ex 4 door. When you are driving at a sustained throttle say 50mph the car misses. As soon as you give it throttle(speed up) The miss goes away. There is no miss at idle and car gets great gas milage.
I have replaced the plugs, wires,fuel filter,cap,rotor,egr valve, all the vacume lines. The car is in correct time. The only thing I havent changed it the tps. There is no cel even if you try to pull one from the ecu there is nothing.
any help would be appreciated I need to get this fixed asap
Old Dec 9, 2009 | 08:29 AM
Default Re: 94 accord misfire
could it be a bad injector?
Old Dec 9, 2009 | 01:29 PM
all these views and no suggetions
Old Dec 9, 2009 | 04:54 PM
nus_dogg's Avatar
Could be a bad injector because it happened to my buddy's 96 Civic EX coupe. He then tapped it with a screwdriver handle and all was fine again. Listen to each injector with your screw driver; you should hear them click.
On my '91 Camry, I had a crack in the distributor housing; not the cap and it was misfiring like crazy and dies at time.
Old Dec 9, 2009 | 05:50 PM
I will listen to the injectors tomorrow. Any other suggestions?
Old Dec 10, 2009 | 06:57 AM
ttt
ben_tech
Oct 11, 2023 08:41 PM
94accord_carve
Mar 20, 2015 12:43 PM
jwicecold
Aug 23, 2008 04:57 PM
bobbysunshine
Jun 29, 2004 12:36 PM
