90 crx si "reving" issues
Old Dec 8, 2009 | 05:32 PM
xTimmyx's Avatar
Default 90 crx si "reving" issues
been a long time member on these boards, some of u seen my rex a couple of times.
i drive a 90 crx si, with a ZC stock swap engine. i have been having this engine "reving" issue for the past year, and frankly its getting kinda worse as it goes, and since winter is already here *and i have nothing else to drive*, starting the car in the winter time is getting kinda scary.
here's the verdict:
only upon cold start up, the engine will start up and run, and proceed to rev up on its own and decellorate *spelling* at a frantic speed steady speed.
as the car decides to warm up after a bit, say maybe 10-15mins, the rev reduces from 3500rpm to 1500rpm, and eventually stops and continues to idle at a steady respectable rpm.
i have been told that the IACV is fubared, but i wanna double check with you guys first and see whats going on, i trust u guys more than i would trust our local mech's. they are a joke.
Thank you all!
Tim *and roxanne (crx)*
Old Dec 8, 2009 | 05:37 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 90 crx si "reving" issues
Sounds more like the EACV... take the plate off of it and see if the ceramic piece is backed out towards the plate. If it is turn it back in, and your problem should be fixed. If that don’t work then blame Canada…
Old Dec 8, 2009 | 06:46 PM
.Manny.'s Avatar
Touching My Member
The FITV underneath the TB?
Old Dec 8, 2009 | 06:50 PM
DO IT ON ALL FOURS
Yeah... the FITV LoL... everybody has their own names for stuff depending on what you read or where you are from.
Old Dec 8, 2009 | 06:52 PM
.Manny.'s Avatar
Touching My Member
I wasn't sure if that is what you meant. That has always fixed the idle issue in the cars I have touched. I always clean the TB as well and check the tension on the throttle cable as well. While I'm in there...
thatruhotsauce
Jun 17, 2005 11:21 AM
King-Kong
Apr 6, 2004 12:02 PM
Nikos
19
Oct 5, 2003 09:12 AM
rschnorenberg
Oct 8, 2002 04:28 AM
WTypeRogerX
19
Apr 30, 2002 01:40 PM
