Help m-f gsr tranny has a bad 5th gear grind! need help with instal!
My gsr tranny has had this 5th gear grind forever i even braught it back to the builder and we replaced the 5th gear but it still grinds, so i got a replacement 5th gear sleave hub and shift fork and need help to install it can any body help me im in sd 92126 any help will be great either a writ up or a shop that will do a legit job and wont mess nothing up or steal anything out. heres the specs.
98 gsr tranny
m factory 4.9 final drive
m factory first gear,
quaife lsd
98 gsr tranny
quaife lsd
as long as you know how to drop your tranny, putting in the new synchro is a novice job for you and a friend as long as you take your time and be thorough
complete write up ...
edit- cant post other forums, sent you a pm
edit #2 cant pm you, full inbox ...
http://honda- tekh.livetopic.com/thread?id=2812
delete the space from the url
Dude... with all due respect, pay attention and just look down the list of topics in this forum and you can find a thread (not very far down either) that will show you how to pull the trans apart, and replace parts on the mainshaft, which is what you'll be needing to do. If you were too hasty to even look for that though, I suggest not doing transmission work yourself.
LOL. I keep my posting to a minimum. But when this thread https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/ is two, I repeat 2, lines down from this thread, we're going to be a bit jaded in responding to you since you clearly didn't take any time to find easily attainable info on your part.
Again, take your time and observe what you do and take apart from the trans.
LOL. I keep my posting to a minimum. But when this thread https://honda-tech.com/forums/showthread.php?t=2443459 is two, I repeat 2, lines down from this thread, we're going to be a bit jaded in responding to you since you clearly didn't take any time to find easily attainable info on your part.
I'm curious to see what your current builder missed and/or screwed up. I'm MFactory's official North American installer so don't have to worry about it not being done right this time.
allmotorrandy was the builder he attempted 2 times to fix it but no luck still a verry verry nasty grind going into 5th double clutching helps, i will pm you about a rebuild !
O wow man my trans(cable b16) is doing the same thing , it grinds its *** off goin into 5th, but a double clutch or rev/speed match works well...also it pops out when you decell on the motorway..I was thinking mybe the shift fork or even shift rod is fouled up I dunno post back when ya got something on it.
cdubracer
Feb 25, 2004 09:46 PM
