Brown Coolant
Old Dec 7, 2009 | 07:00 PM
puSSy's Avatar
Default Brown Coolant
So I checked my coolant today and I noticed that the fluid inside of the radiator is brown. It is kind of a milky color, it doesn't really smell like oil and my oil is still normal. I wouldn't think that the head gasket because it runs normally and it doesn't overheat or anything. Also their is no loss of power because I raced my friend with the same car and beat him. Any idea's?
Old Dec 7, 2009 | 07:25 PM
htownkid's Avatar
New User
Default Re: Brown Coolant
If the head isn't blown then I'm guessing it's rust.
Old Dec 7, 2009 | 08:14 PM
zsudz922's Avatar
do you have an auto trans? if so, check the tranny fluid and see how it looks. the transmission cooler is built into the radiator. so its possible that the inside corroded or something causing the fluids to mix.
Old Dec 7, 2009 | 08:16 PM
thomasetti's Avatar
New User
i'd say its probably rust. check the trans level, and if its ok, flush the cooling system.
Old Dec 8, 2009 | 08:29 AM
Heat's Avatar
Check all fluids and do a flush, then check the radiator on a daily, then weekly basis for a month to see if it returns.
Old Dec 8, 2009 | 09:01 AM
YeuEmMaiMai's Avatar
where would the rust come from all the parts are aluminum including the water pump, radiator insert, and engine block/heads.........the only parts that are steel are the rad cap, impeller, and thermostat and those are not exposed to air.......
509b16
17
Dec 27, 2023 08:01 PM
ssj4trunks09
19
Jan 13, 2008 04:21 PM
Preludesi0080
Aug 19, 2007 07:46 AM
ujhonda
May 28, 2006 08:16 PM
blackEF
Oct 29, 2002 12:24 PM
