NY 93 Del Sol w/ 2000 Civic Si front conversion
SOLD!!!!!!!
1993 Del Sol with 2000 Civic Si front end conversion
1995 B16 JDM motor and 5spd hydro tranny 40k miles
Body: 107k miles
VIS Carbon Fiber hood
Blue HID headlights
Optima battery (relocated to trunk)
lowering springs
Koyo Aluminum Radiator
Hasport motor mounts
Alpine CD player w/ Infinity speakers
New:
Timing belt
water pump
valve cover gasket
wheel bearings
inner/outer tie rod ends
alternator
brake pads/rotors
ball joints
Clutch
Full tune up
Viper alarm w/ pager
Blox short shifter
Distributor
Axles
Front Lip
The Good:
Engine and transmission is mecanically sound, transmission shifts perfectly, suspension is in great shape
The Bad:
the car was keyed on both drivers doors, there is a dent behind the passenger side window, center console is damaged (have a mint one to replace it) i brought the car to a body shop for an estimate, they said around $500-$600 to repair the body
i have extra headlights and tail lights that go with the car
Clean Title (Long Island)
Make Me An Offer
Body: 107k miles
Blue HID headlights
lowering springs
New:
Timing belt
water pump
valve cover gasket
wheel bearings
alternator
brake pads/rotors
ball joints
Clutch
Full tune up
Blox short shifter
Distributor
Axles
Front Lip
The Good:
The Bad:
Make Me An Offer
