Is there a difference between b17 and b18 gsr cams????
My buddy is selling a set of gsr b17 camshafts.. Is there a difference between those and the gsr b18?? I have a si with stock b16a2 i plan on going boost soon would this b the right cam to use if not what would be a better one thanks??
ps: i tried searching the diff. between cams couldnt find nothin
they are the same profiles as a B16. Intake side:230/Exhaust side:227 Keep in mind the B17 is just a stroked b16 motor, everything else is pretty much the same. Run a set of gsr or itr cams with boost, best oem cams to do so with.
what do u mean same profile as b16 cam?? so b17 gsr cam r different from b18 gsr cams?
my b16a2 cam
Int-240 dur. / 10.7mm lift
Exh-227 dur. / 9.4mm lift
my b16a2 cam
yea those specs i put up were at 1mm lift.
gsr cams at 10.7mm lift are something like 265 intake and at 9.4mm lift 242 exhaust.
