Doing work tonight.
Old Dec 7, 2009 | 01:08 PM
Future50's Avatar
Default Doing work tonight.
My M-Factory shift bushings FINALLY came. I got a new OEM shifter to replace my B&M along with all new bushings/guts/orings etc., and a fresh can of mobile 1 grease. I'll be installing tonight hopefully. Any tips? Am I correct in assuming the entire center console has to be removed?
Old Dec 7, 2009 | 01:18 PM
SlapSmak's Avatar
Default Re: Doing work tonight.
I would not use the mobil 1 grease. The best to use is Honda Moly60. 60% Moly in a synthetic carrier. 8$ a tube. Promotes 0% wear, high temp (1500 degrees). I use it on car parts, brake parts, gun parts, etc.
Part Number 08734-0001
Old Dec 7, 2009 | 01:30 PM
BlueIntegraBoy's Avatar
Yeah, you need to remove the center console so you can remove the rubber shifter boot covering the hole.
Old Dec 7, 2009 | 02:40 PM
TheAsian's Avatar
Or you could just pull out the shift boot pull up from the back and it should pop out. Saves a fair amount of time.
Geo4k
Nov 29, 2011 04:55 PM
slowhitEJ1
Oct 30, 2008 11:15 AM
jacksonww
11
Aug 12, 2008 11:55 AM
Wattup Though 00
Mar 25, 2004 04:23 AM
HaadkoeVTEC
Aug 17, 2002 05:56 PM
