clutch problems
Old Dec 7, 2009 | 01:05 AM
v8killaz's Avatar
Default clutch problems
so heres the problem
when i start it it works great and drives fine but at random times it will engage too quickly like no play at all, once i release the pedal liek a half inch the car starts to jerk forward and i almost stall it. i was thinking air in the lines but who knows. usually it has like a 2 inch play, if i pump it or engage disengage it then goes back to normal
also the clutch makes noise when im slowing down with gears engaged, throw out bearing i beleive but would liek to confirm.
guy before said its a stage 2 clutch, but to me it seems to be soem ebay bs clutch kit he bought and thre on it.
Old Dec 7, 2009 | 06:04 PM
z6Dx253's Avatar
New User
Default Re: clutch problems
Hey, I had the same problem. Bleed the clutch fluid OR Is your's a hydraulic clutch? if so then it maybe the "Slave Clutch Cylinder" which contains the bleeder screw NOT the "Master Cylinder". Its located infront of the tranny. Follow the clutch fluid line from the reservior and it will lead you to it. The Slave Clutch Cylinder should have ONE line with TWO male tips at the ends of it. One screwed to the fluid line and the other connected to the Slave Clutch Cylinder. You maybe leaking fluid from there. Replace and issue should be resolved. only like twelve bucks and a half an hour to do. You will need a container to catch the fluid when bleeding, one 10m OPEN wrench and a 10m socket. Good luck!
Old Dec 7, 2009 | 06:05 PM
z6Dx253's Avatar
New User
P.S. New to this site just today!!.....
Old Dec 9, 2009 | 12:44 AM
v8killaz's Avatar
will try this soon
stupid 20 degree weather is coming
so im looking for a heater
Old Dec 9, 2009 | 07:53 AM
da6er's Avatar
yeah i just has this prob yesterday, just bleed the clutch andyou'll be good...
Old Dec 9, 2009 | 08:58 AM
v8killaz's Avatar
thx for reminding me time to bleed it now
hannslebo
Mar 24, 2009 01:53 PM
0260MOTORSPORTS
Jan 17, 2007 07:56 PM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
RiCE On IcE 2
Jun 22, 2005 07:10 PM
respectblades
Jun 16, 2003 07:28 AM
