Couple parts questions
Ok I was checking AEM's website today and found a couple things. First, the bad news. It seems that AEM doesn't make a Big Rotor brake system for the 88-91 CRX Si. Is there something else that is compatible? ALso, in the high performance brake pads section, there is a listing for 88-89 CRX Si and 88-91 CRX DX, but no 90 Si. Again, is this just a bad listing and is something else compatible for my 90Si? Would the 88-89 SI pads fit me?
Next, since I'm running a DOHC ZC, I looked under the listing for 86-93 Integra for the fuel management parts. It seems that the only thing available is a fuel preassure regulator is made for the integ/ZC motor. What I was gunning for is the fuel rail. Will the fuel rails from the other applications work for my ZC?
Lastly, AEM's tru-time cam gears are available for the integra 86-89, but I wanted to make sure that the gears would be compatible with the ZC.
I guess this is just inquiring as I'm shopping around for stuff for my ZC. If you guys have any suggestions on what may be better then I'm all ears. Thanks, let me now what you guys think...
If you want a big brake kit get it from here http://fastbrakes.com/. Its cheap and is easy to install.
About the fuel rail, your really not going to see any hp gain out of it nor the cam gears without upgraded cams or headwork. They do nothing for a stock ZC. Crower makes some nice cams for ZC's. Hope that helps.
[Modified by Losrocket'91, 10:49 PM 9/2/2002]
