Low idle will not go away!
Ive tried everything ..I have adjusted the idle screw 1,000 times it works fine for a littlw while then after it warms up and i hit the breaks the idle drops to 500 every damn time ....Any ideas
Does it shake and try to stall sometimes? Mine goes down too, especially after driving... What a pain in the ***. I did a valve adjustment, checked timing, found no vacuum leaks... Time to get it diagnosed.
I have adjusted the idle screw 1,000 times it works fine for a little while then after it warms up and I hit the breaks the idle drops to 500 every damn time
*All info is from the original 1988 CIVIC CRX Service Manual.
were is that located??? I have a b18b ls motor and my **** goes up and down and stalls alot... i messed with that screw on the TB and got it close as possible.. only does it when it warms up... could it be a bad IACV???
ohh well .. **** .. sorry for waisting my time..
good luck though.. hey.. hmm.. I had to replace a TPS sensor once to fix it.. dunno though..
hey im having the same problem......but heres my deal...I cant seem to adjust my screw.....like mine barely has a slit for the screwdriver and it wont turn for the life of me......
I installed a d16a6 head onto my d15b2 block and converted to mpfi as well...a week ago this worked great...but I took the head back off to do a lil cleaning....now im having problems starting it....the car idles at practiculy zero...wont rev if given gas at all...and will eventually die while also shaking....
What could it be.....bad vaccum line setup or is it somthing more??? idle adjust screw...how can I make my IACV adjust so my rpm is going all over the place...Id like it to get some life and deal with it from there instead of it being thump thump thump and it dies.....
Perhaps the timing??
[Modified by Kasper 1, 5:33 PM 9/2/2002]
Okay I got my idle screw to turn....adjusted it a bit..and it did nothing
but the good news is I checked my timing and it was off like a ****....TDC marks and all.....how I dont know...so I spent an hour redoing that...and boom it started up then I had to fix my idle problem cause I was idling at 2000 do the the screw being open....fixed that now im at a steady 800....and its strong as hell...
I say check your timing.....
fireant
Oct 11, 2006 07:26 AM
slp mode
Dec 21, 2003 08:11 AM
