tire size help with 14 in wheels!
Old Dec 5, 2009 | 02:32 PM
88 EF Hatch's Avatar
Default tire size help with 14 in wheels!
So I have a 88 dx ef hatch, with 14 inch oem del sol fat fives. Time for new tires, so I needed help with tire size. I'm currently using 195/60r14, but I wanted to run 205's not sure if 205/55r14 will be good, but can someone give me some suggestion, if u have any pics of 14 inch wheels on an ef it would be great if you could post. Thanks
Old Dec 5, 2009 | 02:35 PM
92teginsc's Avatar
Default Re: tire size help with 14 in wheels!
i like my 195-60 14's. but they also make a 195-55 but they are expensive. 205's are just too beefy for an ef imo.
Old Dec 5, 2009 | 02:43 PM
I like the 205/50r15's I used to have when I had my ek si wheels, but now I have these 14 in del sol fat fives, I still want some 205.'s if they will work
Old Dec 5, 2009 | 02:51 PM
elf469's Avatar
Honestly, I'd stay with the 195-60-14 just for cost reasons. Plus there are alot of good tires in that size. I've been runnin the 960AS Potenzas, an awesome all season tire.
On tirerack.com a 205/55/14 starts off at $138 each where as the 195/60/14 starts off at $47 to $96 each
Here's a online wheel calculator for you to use. Just input your stock tire size and the size you wanna compare them to...
http://www.miata.net/garage/tirecalc.html
Old Dec 5, 2009 | 02:56 PM
Ok sounds good, but if I were to run the 205's how tall should they be?
Old Dec 5, 2009 | 03:03 PM
elf469's Avatar
Compared to the stock 185/60/14 the 205/55/14 will be closer to your stock diameter. So according to the chart..if you're going 60mph with the 205/55/14 your actually driving at 60.4mph
Old Dec 5, 2009 | 03:28 PM
jhammond_82's Avatar
Reject Papi
cheapest place i ever saw. or you can call local tire shops and ask if they sell used tires in the size you want. what size you want comes down to personal preference. http://ssl.delti.com/cgi-bin/rshop.p...6102&s_p=Tires
cripemaster
May 26, 2010 03:50 PM
88 EF Hatch
Dec 6, 2009 05:37 AM
Red_Si
Dec 15, 2003 02:16 AM
B18CR-X
Dec 4, 2003 05:59 AM
