Transmission & Drivetrain Gearboxes, Differentials, Clutches
Low milage trannys from Japan....
Old Dec 5, 2009 | 02:02 PM
Big John's Avatar
Default Low milage trannys from Japan....
I'm getting closer to repair my 94 civic ( blown tranny) and I see a lot JDM imported trannys from Japan. Most of them is advertised with extremaly low millage. How is this possible ????
I'm just getting to civic world and need some help.
Thanx for all your help
Old Dec 5, 2009 | 02:20 PM
Hanmin's Avatar
Default Re: Low milage trannys from Japan....
In japan, they only have cars for 20-50k miles then junk em...
Old Dec 5, 2009 | 02:34 PM
Big John's Avatar
sounds good, what is the correct jdm trany for 94 civic ex, 2dr, coupe, vtec
anything else I should know before i buy one.
Old Dec 5, 2009 | 03:24 PM
Aquafina's Avatar
"low mileage" does not mean its good.
Old Dec 6, 2009 | 07:05 PM
Finnish_Racer's Avatar
very true, but the Japanese Domestic Market definetly makes a quality product because it is used for daily driving....
i have a d15b and it gets great gas milage......i love jdm way more than USDM
Old Dec 6, 2009 | 07:49 PM
Aquafina's Avatar
Seriously? D15B trans = D16Z6 trans. They're the same thing made in the same place. You know how often the fluids are changed in "low mileage" JDM trannys before they get pulled from the car?
Old Dec 7, 2009 | 12:05 PM
morgan@synapse motorsport's Avatar
I will often times get used transmissions from hmotors when customers bring me unusable, virtually destroyed ones. I have opened up a couple to install lsd's and they have all been great with very little wear on the parts.
Old Dec 7, 2009 | 12:34 PM
Aquafina's Avatar
As have I. HMO is the only place I've received good "low mileage" trannys from, though I have received some with worn parts in them (i.e. bearings from fluid not being changed and gears/shafts with wear). Others I've got from another importer or private party almost always have issues.
Old Dec 7, 2009 | 01:26 PM
Yeah its hard to find mint used gearboxes. I have gotten ones that were full of water from import yards power washing the trannys, pitting and ruining the bearings inside. Whenever somebody bring in a "honda-tech" tranny or one sold from a local ricer it always seems to be bad news. Cases that are sealed with blue or orange silicone throw up red flags and are likely to need repair or were improperly assembled. They are getting older and harder to find.
Old Dec 7, 2009 | 07:05 PM
Big John's Avatar
Got one today from ebay. will pick it up tomorrow and try to install it this week. I hope I can do it my self.
I will keep you posted, if there is anything I should know about replacing it please let me know . Good tips are always welcome.
Thanx a lot.
Old Dec 7, 2009 | 09:51 PM
projectTeG's Avatar
see ive had bad luck with used low milage trannys, i like HMO, but al the trannys ive gotten from there that havent been attached to a swap have been junk. i like hmo, but i would buy the swap before the trans.
Old Dec 8, 2009 | 03:22 PM
Evs-One's Avatar
Solbros Owns Me
haha...I hate that. If you're not going to run HB or the newer trans sealant Honda has, at least use RTV grey! Who uses this blue crap.....every car I work on with blue sealant is just gross
Old Dec 8, 2009 | 05:24 PM
Aquafina's Avatar
I got a trans in about a year ago that was sealed with hot glue.
Old Dec 8, 2009 | 10:27 PM
ramco's Avatar
I recently assembled a trans, with very clean mating surfaces, using no sealant whatsoever, just to test on my lathe. I filled it with ATF and solvent(for cooling) and ran it for a few hours on the lathe at 800 RPM, with no load, then let it set for a few days. It didn't leak one drop. I don't think it takes much to seal these if the case halves are really clean with no burrs. Every one I have seen so far, has way to much sealant on it. I think I could make a tube of that HB last about 500 trannys.
Old Dec 9, 2009 | 02:40 AM
Aquafina's Avatar
They need sealant. Constant temp changes and vibration.
And again (haven't told you in almost two months) stop putting ATF in them.
Old Dec 9, 2009 | 07:33 AM
Hot glue ?
I got one that someone overtightened the plug for the countershaft snap ring and cracked the case there, so they epoxyed the plug and the whole corner area. I hate when idiots ruin things like good trans cases and engine blocks.
Old Dec 9, 2009 | 07:51 AM
JFK78's Avatar
All the trannies we've recieved from hmotors have been mint internally, always been happy with them.
I got a tranny in once that was sealed up with red locktite, every single bolt and the mating surfaces!
Old Dec 9, 2009 | 02:06 PM
Aquafina's Avatar
Hot glue ?
I get a lot of those. Then they complain when I tell them how much it will be to fix it.
Old Dec 11, 2009 | 05:12 PM
blasterman87's Avatar
hmotors doesnt list trannys sepratly on there site, im looking for a jdm b16 tranny, with lsd would be nice. not meaning to thread jack and good luck with the tranny you baught.
S.barron.l
Honda Civic (2001 - 2005)
Mar 1, 2016 01:57 PM
Toy Civic
Jun 25, 2010 07:17 AM
hookups214
Dec 4, 2005 07:50 PM
civiceg500
Jul 31, 2004 05:19 AM
piscorpio
Jan 15, 2003 06:20 PM
