My car wont start
okay so i installed these LED brake lights which suck so i decided to take them out and put back in the OEM lights...well..my intelligent self was a little intoxicated and tried doing this while the running lights were on..i know..
anyway...so something sparked where all the fuses are in the engine compartment and now my running lights and dome light dont work..fine so i check the fuses a few are blown but none that have anything to do with the battery fuse or anything with ignition...when i open the ignition the check engine light comes on and the battery light doesnt come on which normally the battery light stays on while the check engine light turns off then boom it will let me start..but it doesnt let me start it..and the weird thing is when i try to push start the car it wont start but the dome light and running lights come on when i press the break? W-T-F!??!?!?! HELP!!!
normally when you would open the switch just before trying to crank it..the check engine light would come on along with the battery light and you would hear the fuel pump whine meaning it was priming..but you dont hear that anymore the check engine light stays on and the battery light does not come on and there is no whining of the fuel pump so im guessing it might be a fuel pump relay..but the interesting this is when i push start the car that the corner lights come on along with the cluster lights and when you press the brake they turn on off and turn back on as soon as you release the break..would that mean that all those wires are together as one and some of the wires cooked and its affecting everything else that is intertwined with them?
spyke01
27
Apr 26, 2013 10:29 PM
iKhmaiFoSho
Dec 15, 2006 02:20 PM
vtecpower1062
Jun 28, 2004 03:01 PM
