h2b All motor
Old Dec 5, 2009 | 12:04 PM
jdmkid1989's Avatar
Default h2b All motor
hey honda tech, im new to this site and i was thinking about making a serious build but something for street as well because I'm not a rich man, I want to know what type of cams shud i use this is going to be my setup
h2b setup
Full valve job and hone block
m22 or m24 cams(i want good street cams and i dont like skunk2)
supertech valves spring nd retainers
acl bearing
arp head studs
h23 crank
type s pistons to bump up the compression
let me know what you guys think and how much horse power can i make kind of new to the game, i was mostly on style but now want to race a little
Old Dec 5, 2009 | 12:06 PM
jdmkid1989's Avatar
Default Re: h2b All motor
let me know what you guys think and how much horse power i can make nd i dont want to big of a cam and were can i get the m22's
Old Dec 5, 2009 | 12:30 PM
jdmkid1989's Avatar
bumperoni
Old Dec 5, 2009 | 01:06 PM
NAH2B's Avatar
spend a couple days searching, theres plenty of info on here and plenty of pages to read.
as you said your kinda new to motors so its best to learn a bit before jumping into a build
especially after a recent similar thread wasted so much space....
Old Dec 5, 2009 | 03:20 PM
jdmkid1989's Avatar
ur so right i will keep doing my research
Old Dec 5, 2009 | 03:59 PM
ssaccord92's Avatar
I'd get rid of those type s pistons. The valve reliefs on those pistons are a pain with the stroker crank unless u do a custom head gasket thicker of course. So that or get the valve reliefs cut so the valve don't hit the piston but me i'd get a thicker head gasket .051 to .061 it will drop the compression a bit around 11. 5 or so but at least u will be safe meaning no piston to valve or head.
But research alot before doing this its all in here.
Old Dec 5, 2009 | 05:26 PM
JDM JEFFREY's Avatar
there a lot of info out there about h22 and how to make power
why don't you like skunk cams?
Old Dec 6, 2009 | 12:01 AM
speedbynumbers's Avatar
Do your research using type s pistons you have use a .51 cometic head gasket beacuse the piston sticks out of the hole .20. clay your motor afterward to be sure you goo d piston to valve clearance with whatever cam you choose
Old Dec 23, 2009 | 05:31 PM
jdmkid1989's Avatar
to me skunk2 cams are just way to much freaking money
Old Dec 23, 2009 | 06:00 PM
b20vtek's Avatar
but there are known to put down good numbers, not that you can't buy other cams but just my .02
Old Dec 24, 2009 | 10:03 AM
jr_deleon's Avatar
And to add, the Rocket cam packages start at 960 dollars (they only sell them as packages with springs, retainers, spark plugs) Skunk cams are in the 650+ range for Pro Series, and you'd need springs for sure but retainers you could get chromoly KMS ones for 80 dollars. There isnt as much a price difference as you may think (plus there are members here selling them sometimes for 500 dollars or less). So maybe you dont like skunk2 for some other reason
Old Dec 24, 2009 | 10:07 AM
q16racer's Avatar
and you want the above setup?
________
Alaska Medical Marijuana Dispensary
Old Dec 24, 2009 | 02:12 PM
NAH2B's Avatar
the cams are the least of your worrys.
you want to throw an h23 crank in and run s pistons w/ a decent cam....
thats a no no
besides s pistons are a waste of your time, you wont notice a difference w/ them.
either keep the block stock and drop some skunk pro 1s in it = around 1k
or sleeve it and run the h23 crank w/ custom pistons and pro 2s = 3k -4k
or get the h23 vtec bluetop and drop some pro 1s in that. = around 2300.
do some more searching because the setup you listed is not the way to go...
Old Dec 25, 2009 | 01:40 AM
jr_deleon's Avatar
thats a no no
Spoken by one of the few H22 gurus . Take a look at his build-ups, even his stock block version. Very strong
Maciel
26
Mar 20, 2017 10:32 AM
B!NUTZGSR
21
Oct 9, 2008 03:45 AM
allmotorpackage
27
Feb 9, 2007 05:03 PM
averyvm
13
Jan 19, 2007 11:36 PM
JDM*Fiend
Jan 13, 2007 12:58 PM
