question about head swapping
Old Dec 5, 2009 | 10:25 AM
VtecFreePrelude's Avatar
Default question about head swapping
i have a civic with the d16y7 in it and it has a rod knock
i also have a d15something the has a burnt valve.
is it possible to put the 1.6 head on the good block?
is there anything goofy ill run into?
Old Dec 5, 2009 | 10:34 AM
CivicSpoon's Avatar
Default Re: question about head swapping
You'll need to use 9 head studs/bolts from the D15 and 1 head stud from the Y7. That 1 head stud/bolt goes in the back passenger side corner. It's because it's a shorter bolt/stud, and the way the head is designed, it won't seal properly with all D15 head bolts/studs.
Old Dec 5, 2009 | 10:56 AM
can they be reused?
Old Dec 5, 2009 | 02:41 PM
ok i just pulled the headgaskets for both and two holes arent even close... now theres a chance theyre wrong gaskets mainly cause im not sure what engines they are exactly but it doesnt look like theyll work at all... anyone have any input on this?
the holes are on the end one in front and one in back. same place though...
steveharrmr23
Jul 21, 2008 10:28 AM
DA_JDM
May 15, 2007 02:29 PM
busychild
Sep 30, 2004 06:12 PM
anothersickhatch
Jun 8, 2004 07:53 PM
LsTurbo91
Jul 10, 2002 08:58 PM
