CA 96 Acura Integra GSR Coupe w/ B20R VTEC Swap CLEAN TITLE
Old Dec 5, 2009 | 09:56 AM
H2BInspiredDC2's Avatar
Icon5 96 Acura Integra GSR Coupe w/ B20R VTEC Swap CLEAN TITLE
1996 Acura Integra GSR Coupe CLEAN TITLE
222,226 Original Miles on the Chassis & 8,200 miles on the B20R VTEC Motor.
The motor has been tuned and made 227whp & 150wtq with the stock ITR exhaust. My tuner said that the engine is capable of making 235whp with open header and a velocity stack out the headlight. I took it to Sacramento Raceway last Wednesday to see how it performs. The results were:
13.24 @ 111mph w/ 2.1 60' exactly how the car sits with full exhaust and street tires. With 22x8x13 Mickey Thompson slicks and the entire exhaust system removed, and a 1.6 60', I would imagine the car being able to run mid 12's all day.
This car has a list of tasteful mods that make it fun to drive including:
Head:
> P72 GSR B18C Ported/Polished
> Supertech Performance Valvesprings & Retainers & Keepers
> Supertech Performance Valve Guides
> Supertech Performance Valve Seals
> Blox Type-C Camshafts
> Skunk2 Pro-Series Cam Gears
> Skunk2 Pro-Series Ported/Polished & Port Matched 68mm Intake Manifold
> Professional Products 68mm Throttle Body
> NRG Innovations Fuel Pressure Regulator & Gauge
> Fujita ITR 3" Cold Air Intake
> Blox Racing Max-Flow Big Tube Header 2.5" Collector Tri-Y
> P2R Thermal Intake Manifold Heatshield Gasket
> P2R Thermal Throttle Body Heatshield Gasket
Block:
> B20Z2 Honda CRV 85mm
> RS Machine ITR Spec 12:1 Compression Pistons
> ARP Rod Bolts
> Shot Peened OEM Rods
> OEM Acura Main/Rod/Thrust Washer Bearings
> OEM Acura Water Pump
> OEM Acura Oil Pump
> OEM Acura Timing Belt
> OEM Acura Rear Main Seal
> OEM Acura Oil Pan Gasket
> Breather Kit
> LS VTEC Oil Line
Drivetrain:
> Action Clutch 1MS 6-Puck Sprung Clutch
> Action Clutch 12lbs Flywheel
> Innovative Mounts 60A Billet Engine Mounts
Tranny:
> 2001 USDM ITR Tranny LSD w/ JDM 4.7 Final Drive (best gearing for all motor)
Exhaust:
> JDM ITR Full OEM Exhaust Catback
> 2.5" Test Pipe
Suspension:
> Skunk2 Pro-C Adjustable 12-way Adjustable Coilovers
Wheels:
> DRAG DR30 15x7 Wheels w/ Falken RT-615 Tires
Fuel:
> 440cc Fuel Injectors
> 255lph Walbro HP Fuel Pump
> 91 Octane Gasoline
Ecu:
> OBD1 P28
> OBD2A-OBD1 ECU Jumper Harness
> Hondata s200
Asking price: $7000.00 cash. Local buyers preferred. Pink slip on hand readily available. PM me for more information. Thanks.
Old Dec 5, 2009 | 11:00 AM
blazedcivicr's Avatar
Default Re: 96 Acura Integra GSR Coupe w/ B20R VTEC Swap CLEAN TITLE
bump
Old Dec 5, 2009 | 11:05 AM
Heres a video of the motor being tuned:
http://www.youtube.com/watch?v=JE_0chsshqs
Old Dec 7, 2009 | 07:39 AM
Old Dec 7, 2009 | 07:50 AM
srt4mike's Avatar
Looks decent. You should get up some nicer pics.
Old Dec 14, 2009 | 02:31 PM
up
Old Dec 15, 2009 | 04:40 PM
car is still for sale. thanks.
Old Dec 16, 2009 | 04:23 AM
rhdej6's Avatar
ttt
Old Dec 19, 2009 | 07:05 AM
yes sir
Old Dec 20, 2009 | 12:12 PM
Old Dec 27, 2009 | 12:49 PM
Thurman Merman
Northwest (Sales)
Jul 8, 2014 08:07 PM
mashoutposse
Jun 15, 2011 01:48 PM
H2BInspiredDC2
Northern California (Sales)
76
Apr 27, 2010 08:34 PM
H2BInspiredDC2
Dec 28, 2009 07:11 AM
FrancesTheMute
Jun 27, 2008 11:01 AM
