a functional strut brace
Old Dec 5, 2009 | 08:42 AM
schecter's Avatar
Default a functional strut brace
here she is, a REAL work-in-progress! please be kind she's my baby....
I fab'd this up in the shop the other day
a bit of finish work and she's in. a ways to go before it's done. it's very sturdy though, unlike others that mount on the top-hat's.
Old Dec 5, 2009 | 11:19 PM
schecter's Avatar
Default Re: a functional strut brace
nobody likes?
Old Dec 5, 2009 | 11:32 PM
JDMDAEK's Avatar
Good Fab, Might have put more secure mounting brackets for the bar though. Just a suggestion!
Old Dec 6, 2009 | 12:23 AM
thumper64's Avatar
Looks good. I agree it could use a little more reinforcement, but maybe just some like diamond shaped tabs welded to the sides to act as gussets.
Nice looking piece.
Old Dec 6, 2009 | 05:41 AM
turbodcxbro's Avatar
How is that single bolt securing it to the tower better than the usual that bolts to both strut bolts???
Old Dec 6, 2009 | 05:45 AM
supra-n-civic's Avatar
looks good but i agree with ^^^^
Old Dec 6, 2009 | 09:09 PM
thumper64's Avatar
He has two on each side, it appears to attach to the upper control arm bolts.
Old Dec 7, 2009 | 01:49 AM
fastrxu's Avatar
Pretty nice. How long did it take
Old Dec 7, 2009 | 07:02 PM
schecter's Avatar
took less than an hour to mock it up. I agree with ya'll those brackets were just some SCRAP mild steel angle I had layin around, thought they be good for mock up cause they were small but got the job done. LOL they are actually not even drilled I cut out a section of the sides so I didnt' have to remove the bolts entirely. but yes next thing is I tubing the front rad. support ( only the upper portion where the head lights mount) so I have use passive locking hood pins as a latch. and yes those are BOTH of the UCA mounting bolts on BOTH sides. thought a picture was worth a thousand words? j/k thanks guys I'll have more new pics soon. just been busy in the shop to tired to do anything on mine after work....
the wayt you see it in the best picture is what took approx. just under an hour.
Old Dec 7, 2009 | 07:17 PM
FearTheH's Avatar
Hell, ill buy one if you make one that's 96-00 friendly...and make some better mounting tabs. As long as you leave it unpainted but what I really need is some heavier duty sway bars... The factory Si bars aren't cutting it anymore. But good work...mig welded?
Old Dec 7, 2009 | 11:33 PM
Arthas's Avatar
Looks good! Clean it up, mass produce it and sell it bro.
That looks way sturdier than those shitty Skunk2, DC, and Megan Racing strut tower bars.
Old Dec 7, 2009 | 11:37 PM
FearTheH's Avatar
where does that 3rd part that 45's off of the actual brace, mount to? sorry, im just trying to tell where it is mounted but i cant tell lol.
Old Dec 8, 2009 | 12:36 AM
Arthas's Avatar
All ends connect to the A arm 14mm bolts. Its just hard to tell in the pic.
Maybe if it had a nifty powder coat job it would be easier to tell *hint hint*.
Old Dec 8, 2009 | 01:43 AM
desync's Avatar
Reminds me of the neuspeed that came with my del sol...
Old Dec 8, 2009 | 07:31 AM
schecter's Avatar
nice. except this was a much less expensive alternative.... i'm going to tie the whole thing back to the firewall as well.
Old Dec 8, 2009 | 09:53 AM
thumper64's Avatar
Originally Posted by FearTheH
...But good work...mig welded?
I agree, it looks good.
Welds are only as good as the person welding. It doesn't matter what process you're using as long as the person knows what they're doing.
Old Dec 8, 2009 | 10:04 AM
fastrxu's Avatar
Connect it to the engine mount bracket too.
Kinda like the ingals stiffy. Engine damper
Old Dec 8, 2009 | 10:10 AM
FearTheH's Avatar
this is true, but i was asking because different welding, mig, arc, tig, oxy act, and so forth produce different beads... and you cant beat the bead of a nice tig weld
Old Dec 8, 2009 | 10:13 AM
FearTheH's Avatar
kinda, but not hardly... the ingal damper is just a really strong/high pressure shock. it still allows the engine to flex slightly... if this bar was tied into the engine mount it would just bend the bar, i know, i already tried it lol. it was a good idea in theory but just doesnt work out well when coming off of the line hard.
Old Dec 8, 2009 | 10:34 AM
Duc_du's Avatar
should make me one so i can put in my rear upper mount
Old Dec 8, 2009 | 12:47 PM
schecter's Avatar
indeed!!!
i stick welded the tabs on for mockup. tig'd the brace assembly, and will tig the final mounting brackets in as well. greater penetration, cleaner weld, more control over heat, I have a pretty mean variety of welding equipment available to me. the miller xmt w/ water cooled torch, miller pedal, miller switch, using straight argon, i can do anything with that xmt cv/cc machine she's a real beaut!
Old Dec 8, 2009 | 12:58 PM
uwishucould158's Avatar
i like but i also agree on the itty bitty brackets
Old Dec 8, 2009 | 01:04 PM
Deetz's Avatar
Crazy Honda Guy
Hmm, the design is much like the older Neuspeed bar, and would provide the same support. I bought one used off of ebay for like $60. Not sure if it would be worth you doing it for a profit or not. A front upper strut bar does add some support, it's not huge though, many newer Honda's have pretty good chassis to begin with.
Adding a good set of sway bars would provide a huge difference in performance if that's what you are looking for.
here's a decent shot of a neuspeed bar on a crv, lol
Old Dec 8, 2009 | 01:19 PM
Pothole987's Avatar
what gauge is the steel? i was going to make one for my old car but for 20 bucks i bought the c type that blolts to the firewall.
Old Dec 8, 2009 | 02:25 PM
Duc_du's Avatar
why does OP bay look all burnt up. was it in a fire or something???
