Super duper moving sale, low ballers paradise--teg for sale also
Alright guys prices
I got them goodies...buy something.
1 boost gauge sold: mazdaholic
a/f gauge sold: 90preludeLad
crx corners sold: craigs
climate control sold:meandino
hf mani, 14b turbo and dp sold
d series OBD0 dizzy sold:craigs
450cc injectors sold:craigs
2 1/2" flex pipe sold:craigs
both corner lights sold on craigs
short shifter sold
http://i295.photobucket.com/albums/m...3/DSC_0228.jpg
crx d series shift linkage and ebay short shifter sold
honda steel rim center caps 10 bucks
hf manifold 10 bucks
crx manual trans starter 15 bucks
crx hf axle shafts 20 bucks for both
Obd0 d series ngk spark plug wires 15 bucks 30 miles or less on them
d16z6 and d16y spark plug wires 30 bucks under 250 miles
http://i295.photobucket.com/albums/m...3/DSC_0229.jpg
apexi vafc with pig tail 70 bucks
crx hf cluster 5k rpm redline 10 bucks
black and gray crx dash 20 bucks picked up only
crx tail lights does not fog up no gaskets 10 bucks
crx cooling fan 10 bucks
crx fly wheel, clutch, and pressure plate will mate 88 d series cable trans with 89 up engines. 20 bucks
http://i295.photobucket.com/albums/m...3/DSC_0231.jpg
chipped pm6 with stock map burned chip 75 bucks
http://i295.photobucket.com/albums/m...3/DSC_0232.jpg
top is a crx hf ecu no problems with it 10 bucks
center is a crx si ecu no problems with it 30 bucks
bottom is the chipped crx si ecu 75 bucks
Also have some chips for sale 20 bucks for 3 of them
http://i295.photobucket.com/albums/m...3/DSC_0233.jpg
crx light switch 10 bucks
crx wiper switch 10 bucks
crx main relay 30 bucks
crx emergency switch 5 bucks
crx under dash fuse box with thingy clipped onto back 20 bucks
http://i295.photobucket.com/albums/m...3/DSC_0235.jpg
top down
2" charge pipe with no bov 10 bucks
14b to hf mani adaptor plate w/bolts 30 bucks
2 1/2" charge pipe with dsm bov 20 bucks
2" charge pipe wth dsm bov 20 bucks
2 1/2" obx test pipe/resonator/whatever you want to call it sold
close up of 450cc dsm inj. sold
http://i295.photobucket.com/albums/m...3/DSC_0237.jpg
oem front lca's 15 bucks a peice 25 for both
http://i295.photobucket.com/albums/m...3/DSC_0227.jpg
90 integra washer fluid tank 5 bucks
90 integra blue center trim with shift boot 5 bucks
90 integra blue ebrake trim 5 bucks
90 integra ls obd0 alternator with plug wires 50 bucks
90 integra cluster trim with all switches 20 bucks
90 integra cluster 30 bucks
90 integra starter 20 bucks
http://i295.photobucket.com/albums/m...3/DSC08398.jpg
88 crx dx transmission will bolt up to 212mm d series flywheel with my clutch and pressure plate set up. 40 for trans
http://i295.photobucket.com/albums/m...3/DSC08399.jpg
90 integra ls axle shafts. No problems with them. 70 for both 45 for the one with intermediate shaft. 30 for short side.
http://i295.photobucket.com/albums/m...3/DSC08400.jpg
90 integra front spindles with caliper, upper control arms and brake hoses. everything works. 50 bucks
b18a oem headers to cat 10 bucks.
90 integra alternator barely new will need new pulley. 40 bucks
90 integra ac compressor with bracket 20 bucks.
90 integra shift linkage with oem shifter 20 bucks.
http://i295.photobucket.com/albums/m...3/DSC08401.jpg
http://i295.photobucket.com/albums/m...3/DSC08402.jpg
90 integra sedan doors. Pretty good condition but LR side now has a scratch. 20 bucks a piece
http://i295.photobucket.com/albums/m...3/DSC08405.jpg
blue 90 integra dash 20 bucks.
90 integra gs fuel tank w/new fuel pump 20 bucks
everything is ****ing priced low, throw me offers, need to get rid of everything...bring 250 bucks and a truck and take everything!
Now for the car.
I have a 96 acura integra LS.
Has, AEM CAI, ceramic, DC sports header and DC sports exhaust. Rusto'd black, body condition is probably 7 out of 10. Runs like a champ. 200k miles on it, only thing that doesn't work like its supposed to is the gas gauge. Last gauge had a funky speedo problem, this one had a gas gauge problem :S. 5 speed, black exterior, green door jambs, tan interior. Has ac and ps. Stock cd player. Lets start at 2000 obo? Any other questions let me know.
short shifter sold
top down
Now for the car.
stevens point, wi. Basically central wisconsin. I'm going into the military so I need to get rid of all my car and parts :S.
so was the car green originally? Do you have any interior shots and engine bay shots? Also of the jams? Also how's the rust?
rice a roni
Aug 23, 2009 10:35 AM
