Has Anyone tried polishing valve cover.
Old Sep 2, 2002 | 10:25 AM
Civmochris's Avatar
Default Has Anyone tried polishing valve cover.
I am trying to polish my new valve cover. i was wondering if anyone out there had a better idea than what i am doing. i am useing a drill with a soft brissle wire brush attachment.
Old Sep 2, 2002 | 10:35 AM
JDMITR222's Avatar
Default Re: Has Anyone tried polishing valve cover. (Civmochris)
that will take forever,just take it to a polisher.Trust me you'll be more happy with the results rather than spending hours and hours sanding then polishing it out.
Old Sep 2, 2002 | 01:24 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Has Anyone tried polishing valve cover. (JDMITR222)
I have a great idea.. use the SEARCH utility.. because there are a million topics on this and how its done. Not to be a dick.. just giving you the heads up.
Old Sep 2, 2002 | 02:08 PM
B00STeD's Avatar
a friend of mine did this himself and it came out beautiful!!!
but it took a hella long time
take to a polisher if you wanna save time but if not do it yourself
Old Sep 2, 2002 | 06:43 PM
civbeater90's Avatar
Default Re: Has Anyone tried polishing valve cover. (B00STeD)
um this was done by hand-sorry for the big pic
Old Sep 2, 2002 | 07:30 PM
teg92's Avatar
When simply refinishing my valve cover I realized how much work it was for just making it "look" prettier. If you are going to polish it, spend the money and get it done right. Half *** polished stuff looks like crotch!
Old Sep 2, 2002 | 07:56 PM
mantic6t9's Avatar
Default Re: Has Anyone tried polishing valve cover. (teg92)
Old Nov 22, 2002 | 05:37 AM
SM Polishing's Avatar
If you want to do it yourself the best way to do it is take the time and use plain old sand paper. Start with a low grit, around 150 depending on if there are any stray marks... then work up to about 2000 grit. Then use a buffing wheel and polish it to that elusive mirror shine once you've removed ALL those little casting dimples...
Check out my website for some picture... http://www.smpolishing.tk
Hope this helps,
Scott
Old Nov 22, 2002 | 06:19 PM
Danger's Avatar
Default Re: Has Anyone tried polishing valve cover. (smpolishing)
after your done with the soft wire wheel switch to a buffing wheel and try different buffing compounds . mothers polish works good for the final . good luck
Old Nov 22, 2002 | 08:53 PM
Default Re: Has Anyone tried polishing valve cover. (jonny5)
i agree that is what i used on mine and you can see the results on the pic a few replies up.
jdmmuzzle
Sep 11, 2008 07:33 AM
AccordSleeperZzZ
Feb 24, 2008 08:37 PM
Okininam
Oct 12, 2006 11:51 AM
Brett
Jan 6, 2003 06:42 AM
