Where do I buy a brake booster delete?
Old Dec 4, 2009 | 04:48 PM
lampshadej1's Avatar
Default Where do I buy a brake booster delete?
ive been looking around but i cant find where to get a brake booster delete for my 95 civic..
i see chasebays has one but its not out yet or something??
anyone else know where to get one?
Old Dec 4, 2009 | 05:32 PM
ChRiS_p123's Avatar
Default Re: where to buy brake booster delete??
may be a stupid question, but whats the point wouldnt that dramatically reduce braking power?
Old Dec 4, 2009 | 05:44 PM
elf469's Avatar
From the chasebays site, it says for thier Oct. 20th post its $235 shipped. The Sept. 7th post said they were having issues with the machine shop. I'd call them on Monday to make sure.
Old Dec 4, 2009 | 05:46 PM
Got traction's Avatar
bisimoto makes one
Old Dec 4, 2009 | 06:04 PM
joelmatt89's Avatar
I am also wondering this as well are you trying to free up space in the bay or something, seems like a lot of money for effectively a down grade. However I don't think in a civic it would really be a big deal. I drove a jeep with manual brakes for a few years as a daily. Your leg just gets stronger from it haha. Is this just to clean uo the bay, this is really curious to me I would think this could be very complicated. Besides the fact the break setup was not meant to deal the with the huge increase in force applied to the pedal, I would think you will also have to modify the master cylinder etc. to get this to work properly.
Old Dec 4, 2009 | 07:34 PM
yea,
well my brake booster is bad thats in it right now,
and i did a wire tuck recently so i was gonna do a brake line tuck and booster delete to go with it..
i know itd be harder to brake but eventually ull get used to it, aha
Old Dec 4, 2009 | 07:53 PM
zcar4me's Avatar
Dumb "mod" if you ask me.
Old Nov 25, 2010 | 06:56 PM
macknjack's Avatar
where do you get just the plate? i saw that downstar has one but it is sold out and are only making limited quantities
Old Nov 25, 2010 | 06:58 PM
4stagecandy's Avatar
all in fabrication makes one
Old Nov 26, 2010 | 06:26 PM
macknjack's Avatar
Default Re: Where do I buy a brake booster delete?
cool, checked it out.
does anyone know why they only do the booster delete plates compatible with newer mc's? i have a 90 civic and dont see the point in chaging the mc if i am not going to be changing the size of it.
Old Nov 26, 2010 | 06:29 PM
98civdx's Avatar
Master Detailer
Rywire also makes one
Old Nov 26, 2010 | 06:42 PM
macknjack's Avatar
i have not seen his. either way i think i am going to have someone make me one for my master cylinder unless someone can explain to me why i need to change to the 92 + style
Old Nov 26, 2010 | 07:58 PM
spun95's Avatar
If your gonna replace the booster with a plate, wilwood makes a set that comes with a plate, mc and a new brake pedal that has a higher 6:1 ratio, over the factory honda 3:1, for easier stopping without the booster.
Old Nov 26, 2010 | 10:03 PM
macknjack's Avatar
yes but then you have to make new hard lines. the wilwood mc only has one output line. my braking system has two line that run to the prop valve :/
Old Nov 26, 2010 | 10:05 PM
98civdx's Avatar
Master Detailer
They make a T fiting for that, one line in 2 lines out.
Old Nov 26, 2010 | 10:45 PM
spun95's Avatar
yea but if your going for the delete then your gonna have to make a line fabrication. willwood has a y valve that comes in the set
Old Nov 27, 2010 | 12:49 PM
H22AFerio's Avatar
I thought there was some kind of electric booster you could buy?
Here is somthing similar that i was talking about. its for hot rods but its a one size fits all kinda thing lol
http://www.abspowerbrake.com/electrichppage.html
Old Nov 30, 2010 | 07:05 AM
macknjack's Avatar
ya true and i was thinking last night that if i do the booster delete i cant use my carbing strut bar with master cylinder brace. it would be too short
Old Jan 11, 2011 | 09:52 PM
lsvautocross's Avatar
For you guys who are'nt sure why you would do a booster delete, it is more for racing like autocross with a boosted car. For example when your driving on the straight your at full boost when you come to the turn at the last second you let off the gas and slam the brakes, but now you have negative boost so your booster doesnt do nothing and now you need to let off and hit the gas again and hopefully you have enough distance still to stop!!! the delete makes you have direct response when you hit the brake but like someone else said it just a little harder pedal. when you use the delete you also want to get the adapter to reduce the brake pedal arm swing so you have more brake power with less pedal travel.
pearlteg
Dec 12, 2005 05:54 PM
Prelude SIR-T
Jul 21, 2005 08:16 PM
martilafox
Aug 1, 2002 07:53 AM
