S2000 Header I have been working on
I haven't been on here as much since I bought my 2002 S2000....but I thought I might share something that I have been working on.
I decided there wasn't really any documentation regarding HP improvement the headers for the s2000 and so I decided to have one built.................ANd since I have access to a dyno...document it
Big thanks to Jeff @ Fast Forward for all his hard work on this
We tested it on both a AP1 and an AP2....
As you can see in the final chart...we made a little progress................
2002 F20C with 67k on the motor
AEM V1 CAI
Greddy 70mm single TiC
Invidia 70mm TP
only change is the header...no tuning
solid line is run file from the left
dotted line is run file from the right
Ok here is the 1st chart showing baseline versus the Fast Forward header
Here is the baseline vs the Fast Forward Header v 1.3
Here is version 1 vs 1.3
here is the current version.........
red line is the current header
blue line is the baseline/OEM header
Solid line is the file on the left and the dotted line is the file on the right
solid= FF header
dotted= OEM
OK here it is.....the Final version of the OEM sized replacement header
we were pretty happy with the gains from previous version
Purple is Final version
Red is previous version
here is the overlay
Solid is Final version
Dotted is previous version
Here is OEM vs the Fast Forward Header
Purple is FF
Light blue is OEM
Solid is FF Header
dotted is OEM
AP2 results
100% Stock 2004 AP2 S2000 with 30k on it
Green Line is best baseline run vs
Purple line :best run with Fast Forward Header installed
After a few more runs we did a ECU reset........
before the ECU reset....we pulled the airbox lid off and directed cold air at the filter.....just for ***** and giggles...
BTW the fan was back aways from the box..not crammed up
AEM V1 CAI
Invidia 70mm TP
solid= FF header
dotted= OEM
here is the overlay
Purple is FF
Light blue is OEM
Solid is FF Header
dotted is OEM
AP2 results
VtecKiDD
Performance
15
Oct 13, 2009 09:24 AM
ScubaStevo80
13
Oct 10, 2003 09:18 PM
