Car Wont Start / Idles Rough...Need help
Old Dec 4, 2009 | 08:32 AM
tedo2007's Avatar
Default Car Wont Start / Idles Rough...Need help
Car wouldnt start last night at the gas station, after several minutes of trying, i finally got it going, drove it home no problems...
then today i go out, wont start at all (turns over, just like last night) but wont start
so i removed the negative cable, waited a bit hooked it back up, now it starts, but it does this
http://www.youtube.com/watch?v=_ww1RD-QPfc
very rough start, once it starts it runs just fine....
main relay must be good, i hear it clicking as well as the fuel pump!
Old Dec 4, 2009 | 08:34 AM
Former User's Avatar
Default Re: Car Wont Start / Idles Rough...Need help
Any CEL codes?
Old Dec 4, 2009 | 08:36 AM
tedo2007's Avatar
no codes....
Old Dec 4, 2009 | 08:37 AM
Does the CEL work -- on for 2 seconds and then off when key is turned to ON(II)?
Old Dec 4, 2009 | 08:39 AM
tedo2007's Avatar
yep, i had a cel a couple weeks ago for my o2 sensor, changed it out...
after that rough start, itll stay running no problems...
cap? rotor? or would that not do that?
Old Dec 4, 2009 | 08:40 AM
How old are the plugs, wires, cap, and rotor? Have you inspected them?
Old Dec 4, 2009 | 08:41 AM
tedo2007's Avatar
plugs 2 weeks old
wires, 6 months
cap and rotor - never changed or inspected
Old Dec 4, 2009 | 08:43 AM
Originally Posted by tedo2007
plugs 2 weeks old
wires, 6 months
Definitely pull the cap off and inspect the inside contact points as well as the corresponding contact on the rotor. Post pictures if you can.
Old Dec 4, 2009 | 08:45 AM
tedo2007's Avatar
i will say, when i tried to start it at the gas station when it wouldnt start, it was like it just turned over and finally it did what you see in the vid, and started
Old Dec 4, 2009 | 08:46 AM
tedo2007's Avatar
whats the easiest way of getting the cap off? its alot easier on a 440 big block
assume its the 3 screws? the one looks hard to get to..lol
Old Dec 4, 2009 | 08:48 AM
Just remove three bolts to get the cap off:
Old Dec 4, 2009 | 09:07 AM
tedo2007's Avatar
http://www.youtube.com/watch?v=6Kq3gTSQU0I
Old Dec 4, 2009 | 09:08 AM
tedo2007's Avatar
both look very worn, would that cause my problem?
Old Dec 4, 2009 | 09:58 AM
tedo2007's Avatar
thanks man, i owe you a million, ....changed the cap and rotor, runs like it never has since i bought it a year ago!
95blackEG
Dec 29, 2008 12:44 PM
ek_b16
Sep 7, 2005 10:35 AM
jdmtim
Nov 11, 2003 04:32 AM
Honda Sport
Jun 4, 2003 05:27 PM
