Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Final answer on intakes vs CEL
Old Dec 4, 2009 | 06:29 AM
Ricey McRicerton's Avatar
Default Final answer on intakes vs CEL
I did my searching.
There seem to be very mixed answers on the issue of a CEL with a aftermarket intake on the new Civics. It's time to swap out my air filter, and I'm throwing in a K&N filter if I'm going to end up with a CEL on a brand new car because of the MAF.
Thoughts/opinions?
Old Dec 4, 2009 | 07:58 AM
07SIcpe's Avatar
Default Re: Final answer on intakes vs CEL
I'm pretty sure a drop-in filter won't throw a CEL. I have an SRI and no CEL's and I've had it on for almost 20k miles. I think you're good...Hell I don't even have a cat and no CEL lol..
Old Dec 4, 2009 | 08:03 AM
Sorry, I realize now that what I typed was a little unclear. I'm sure the drop in won't cause the cel, but wanted to make sure if I dropped the money on an aftermarket intake, I wouldn't end up with a CEL.
Old Dec 4, 2009 | 08:06 AM
Greg50Lt's Avatar
if you get an aem or the fujita. i think those cause can casue a CEL, but i have had the k&n and now the takeda. I hear good things about the injen as well.
Old Dec 4, 2009 | 08:32 AM
07SIcpe's Avatar
sorry I read through your post a little too quick. But I see what you mean now. I have an Injen SRI and no problems at all. Sounds great and also feel a gain. No regrets on my end.
Old Dec 4, 2009 | 08:46 AM
RICO_'s Avatar
NO MERCY!
My Fujita hasn't once given me a CEL since I installed it nearly 2 years ago. I disconnected the battery prior to install (like most other people have done) and let the car idle for about 15 minutes after the install and haven't had any CELs, bogging, or rough idles at all.
Old Dec 4, 2009 | 08:58 AM
07SIcpe's Avatar
So pretty much if you follow those basic steps for installation, mainly disconnecting the battery, you should be good..
Old Dec 4, 2009 | 11:11 AM
chiggin's Avatar
Do that ^
I did that when I installed my Injen SRI and I never had any problems at all.
Old Dec 4, 2009 | 01:09 PM
Nexx's Avatar
Can't say for sure for our "picky" cars as intakes are not made equal even with brand name products. I've owned both the INJEN short and the over-priced MR technology CAI version and both have given me a fair amount of trouble (the SRI more so than the CAI). I've driven days without a CEL only to get one out of nowhere. I've triple-checked installation, battery disconnection and done ECU idle runs with no viable long term solution. What's strange is that my friend's fujita SRI ran perfectly fine on both of our cars but experienced the same issue with the INJENs. Very few manufacturers (AEM only) have addressed the disruption caused to the MAF by the increased air flow of the new intake design. Stabilizing fins at the MAF should be the norm for our MAF sensored cars.
EDIT: It's been a few years but if I recalled correctly, the fujita SRI that was used did not have stabilizing fins. New ones may be different? Can anybody confirm?
I currently have a DIY modified MAF housing SRI and would not trade it for anything. Why did you I switch from the CAI? Simple. Throttle response/hesitation. I use my car as a daily driver and I couldn't stand the bog below 4000rpm even though I may have more high-end power.
Old Dec 4, 2009 | 01:17 PM
builthatch's Avatar
MiG-21 superfan
here are some recent posts i made in threads about this sort of thing-
Originally Posted by builthatch
i'm curious....does the fujita have vanes near the MAF, inside? i know on alot of the new MAF cars, like my Mazdaspeed3, such vanes are absolutely required to prevent turbulence and confusion for the MAF. they "straighten" the air approaching and passing the MAF.
i wonder if that is the issue with this intake you are using. you should call fujita, maybe they revised the design and the one you have is an old one? i know that AEM, who was contracted to make the cold air intakes for Mazdaspeed, had to supply these finned inserts after Mazda put a stop sale on the intakes because of issues and check engine lights. sure enough the straightener insert solved allllll the issues.
yeah, i assume they reduce turbulence and help the MAF measure reliably. AEM engineered a MAF housing in their si intakes with specifically engineered vanes for this reason. i know it was crucial in the mazda world. in fact, mazdaspeed had to recall their own intakes (made by aem). they pulled the ones they had left and aem engineered a vane insert. this was because several companies, cobb included, were successfully making intakes with properly designed MAF housings and having great success. the mazdaspeed units were causing issues.
also, somewhat unrelated, but a note on resetting-
https://honda-tech.com/forums/showpo...&postcount=157
Old Dec 4, 2009 | 01:36 PM
JDMsam.'s Avatar
I've had the mishimoto in and didnt throw a code till 6 months/10k miles later.
checked the code said i was running rich on cylinder number 4. So you could get an intake and throw a code later on. get flash pro and run map.
Old Dec 4, 2009 | 02:20 PM
Ben850's Avatar
+1 for injen SRI, 15K miles so far without a single CEL. I also disconnected battery and let idle for 15 min after the install.
Old Dec 4, 2009 | 02:45 PM
ChargedSI's Avatar
I have had a AEM CAI for 2 years and never gotten a CEL. My mechanics installed a Wideband O2 sensor (I think) when they did the CAI. Not sure here, but that "might" be why I never got a CEL. I need to check my paperwork. I know they installed a Wideband something, but now that I think about it more, the Wideband O2 sensor might have been for the A/F gauge which was installed much later.
Old Dec 5, 2009 | 07:30 AM
2008fijibluesi's Avatar
Fujita is junk. RICO is one of the few lucky ones. Mine gave me nothing but problems. My car has never run right since the Fujita was giving me problems.
Old Dec 5, 2009 | 09:24 AM
Greg50Lt's Avatar
Your right Rico, the issue with the fujiti intake is not the cel.
I just looked it up and it was the issue hondata had when tuning si's with fp. The fujiti gave a very inconsistant reading of air fuel ratios.
I think that the best intake on the market is probably the injen even thou I do love my takeda
Old Dec 5, 2009 | 09:47 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Only intake I ever heard of throwing a CEL was the version 1 AEM cold air and short ram intakes, I ran an Injen SRI for around 30K and a Mishimoto for the last 10K I had the car and never had any problems. I removed the battery during both installs and did the idle for 15 minutes deal the first time, not the second time around. Never had a single problem.
Old Dec 5, 2009 | 10:16 AM
i-VTEC_DOHC's Avatar
a k&n drop in filter wont cause a cel. its the actual design of the aftermarket intake that causes it. like tokyo said the version 1 aem intakes would throw cel's left and right. my friend has a fujita sri, and it wont stop throwing a cel. he'll reset the ecu, and it would go away, but about 100-150 miles later, it comes right back. my injen sri that i had for about 20k miles, never threw a cel no matter how hard i tried.
Old Dec 6, 2009 | 01:53 AM
JustinG60's Avatar
i have the Takeda on my FG2 and no CEL...
Old Dec 6, 2009 | 12:41 PM
Greg50Lt's Avatar
^^ So you finally go yours in. How do you like it?
Old Dec 6, 2009 | 08:53 PM
i sort of want an intake again.
aww shucks
Old Dec 7, 2009 | 03:55 AM
Why'd you get rid of yours in the first place ivtec?
fandirabbani08
Nov 1, 2006 11:33 AM
ScrewDriver9
Jun 11, 2005 06:38 AM
deviant1
May 1, 2004 01:54 PM
stizzit
Jun 5, 2002 01:25 PM
