Swapping a B16A (1st Gen) into a stock 91 Civic HB
Old Dec 3, 2009 | 02:55 PM
Mrpiccolo444's Avatar
Default Swapping a B16A (1st Gen) into a stock 91 Civic HB
Ok... I tried to find this on here but couldnt find it, and you guys have been very helpful getting me info on what to look at and how to find certain info.
I have a straight stock 91 Civic Hatchback... no alterations yet. I am looking to get me a B16A (1st Generation) for my car. I was wondering what parts will I need on top of the engine and transmission to make it fit my car.
And how do I go about getting them? Any and all info would be helpful. Thanks for your guys time.
Old Dec 3, 2009 | 03:23 PM
L.G.A.R.S's Avatar
Default Re: Swapping a B16A (1st Gen) into a stock 91 Civic HB
this will help u whit the parts.i just finish mine and it was a succes.i used this page for the parts.
http://hondaswap.com/swap-articles/p...d0-swap-25274/
r u staying OBD0?
Old Dec 3, 2009 | 03:42 PM
LOL... Your going to have to forgive my ignorance but I am still new to all this. I have seen that term around... whats it stand for or mean?
Old Dec 3, 2009 | 03:45 PM
89s1's Avatar
*walks in*
*looks around*
*runs*
Old Dec 3, 2009 | 04:04 PM
L.G.A.R.S's Avatar
Originally Posted by 89s1
*walks in*
*looks around*
*runs*
lol!
thats the kind wiring that comes whit ur year civic. it changes whit each generation civc i belive. what model civic do u have dx or si? becuase u might have to do the famous 2 injector to 4 injector swap.or DPFI-MPFI swap
Old Dec 3, 2009 | 04:13 PM
Oh I see... Yeah I think I gotta don't I... I have a 91 HB DX
Old Dec 3, 2009 | 04:24 PM
smokey68321's Avatar
you'll have to DPFI to MPFI swap ... i have same car, same motor
Old Dec 3, 2009 | 05:34 PM
whiteb16crx's Avatar
basically you have 2 injectors and to swap the b16 you need to add 2 more injectors. or just get a obd1 or si harness
Old Dec 4, 2009 | 07:59 AM
The engines I keep looking at come with the ECU and the wires to it... wouldnt that take care of it... or am I looking for something more?
Old Dec 4, 2009 | 08:15 AM
4drEF's Avatar
Keyboard Humorist
http://lmgtfy.com/?q=how+to+swap+b16+into+ef
Old Dec 4, 2009 | 08:36 AM
90da4dr's Avatar
Loved
OBD = On-Board Diagnostics. i think
0 = 88-91
1 = 92-95
2 = 96-2000 -1
If you are using the pr3 ecu which might come with the swap then its obd0.
if you plan on using a chipped p28, etc. then its obd1
Old Dec 4, 2009 | 09:08 AM
Thank you... that was an awsome list of very detailed instructions... I really appreciate it :-D
Old Dec 4, 2009 | 09:24 AM
ok... I got another question... this article said to get a PR3 ECU... but when I do research on it it says it is a OBD0 does that have the 4 injector controllers???
Old Dec 4, 2009 | 09:29 AM
And while I am at it... I gotta another question. Lets say I need to replace my spark plugs, alternator, timing belt, starter and what not. It says that I need to goto the auto part store and get the ones made for a del sol. Is that correct and if so what year??? It didnt say.
Old Dec 4, 2009 | 09:30 AM
4drEF's Avatar
Keyboard Humorist
0 = 88-91
1 = 92-95
2 = 96-2000 -1
I have a PR3 sitting on my desk that is OBD1 - they come in both OBD flavors.
Old Dec 4, 2009 | 09:31 AM
Which one should I use and what do I get it out of?
Old Dec 4, 2009 | 09:36 AM
4drEF's Avatar
Keyboard Humorist
Every engine EXCEPT the 88~91 DX/LX/STD 1.5liter motor has 4 injectors.
Check out this link for some easy info on visually identifying the OBD of an ECU.
http://www.hondata.com/techecuid.html
Old Dec 4, 2009 | 09:49 AM
4drEF's Avatar
Keyboard Humorist
OBD is specifically the electronic engine management system on the motor.
The motor itself can not be identified with the term OBD.
Each OBD version has a few specific electronic sensors that are unique to it's version.
If you buy the motor and the ECU isn't included, then you will have to figure out what OBD set up is on the motor.
You can 'sort of' go by the year of the engine, BUT performance minded people often change electronics for tuning. It is easier to find people to tune and OBD1 system than OBD0 so people change out to necessary items on they factory OBD0 engine to run the OBD1 ECU.
Old Dec 4, 2009 | 10:02 AM
90da4dr's Avatar
Loved
My bad, I forgot about that. (SIR and del sol).
Old Dec 4, 2009 | 10:25 AM
OK... another issue... I know that 1st Gen has about 160 HP and 2nd Gen has 170 HP and some of these places Im looking at dont specify 1st and 2nd Gen. Due to the money of it Im going to line up and buy all the parts before I get the engine (1st Gen). How screwed am I if I accidently wind up with a 2nd Gen after I buy all the parts?
Old Dec 4, 2009 | 10:36 AM
BTW... I want to say thank you guys for being patient with me and explaining things simply and thoroughly. I really appreciate it :-D
Old Dec 4, 2009 | 10:41 AM
OK... I got an easy one for you. Im looking at buying these seats
http://cgi.ebay.com/ebaymotors/88-91...item2ea97969c4
Has any of you or anyone you know bought these before... if so do my stock brackets fit to their universal sliders???
Old Dec 4, 2009 | 11:39 AM
i've used parts from a 94 Del Sol vtec.... and a 90 integra
Old Dec 4, 2009 | 01:01 PM
89s1's Avatar
That right there, is genius.
Old Dec 4, 2009 | 01:05 PM
89s1's Avatar
I put an sirII (second gen) b16a into my 89 hatch.
If you have decided to go obd0 and you get a second gen motor you'll need obdo injectors, distributor and ecu. then you're good to go.
