new crx owner, need help
Old Dec 3, 2009 | 06:01 AM
josh7owens's Avatar
Default new crx owner, need help
hey guys,
I'm new to honda-tech but not new to hondas or modding. I also post on s2ki and have a 00 s2k. I just picked up a crx last night. Its a 91 with a d16z6 swap. I dont really know alot about crx's so I would like so help of fixing a couple things. The per. owner said he had 17's on it and when he went back to the 13's he said he never tightened the traction bars in the front. it seems to have a popping noise when you take off or turning. Would tighting the traction bars fix this? It has a stage 2 clutch in it but I dont think that has anything to do with it.
also the motor burns oil and I'm debating on if I should rebuild it or If I should just keep saving and go on and do a b16a2 swap.
Old Dec 3, 2009 | 07:43 AM
BiGZ's Avatar
Default Re: new crx owner, need help
Search + read the FAQ stickied at the top of this EF section,will answer 99% of most ?'z.
CV axles "pop" once they start going out,especially on hard turns...
Old Dec 3, 2009 | 01:37 PM
josh7owens's Avatar
thanks for the advice I'll check it out.
I have a new problem. it wont idle smoothly. It keeps idling up and down. do I need to replace the ICV or would it be somthing else?
Old Dec 3, 2009 | 02:30 PM
xalents23's Avatar
Try cleaning your ICV to fix your idle.
Old Dec 3, 2009 | 02:39 PM
egcivic4life's Avatar
if its a high milage engine valve stem seals or piston rings. i had the same problem with mine.
Old Dec 3, 2009 | 07:25 PM
josh7owens's Avatar
the motor has around 100,000 miles on it. so it is high miliage. It does burn oil pretty bad though. do you have a link to how to clean the idle control valve?
Old Dec 3, 2009 | 08:59 PM
USNneverAGAIN07's Avatar
its on the back of your intake manifold, two bolts hold it on. Its really simple to pull and clean. If you pull it make sure you have a new gasket for it also. If you look in the EF sticky it covers on pulling it and cleaning it out. Just pulled mine it had wood and leaves in it. If that dont fix it I would start looking for a vaccum leak.
Old Dec 3, 2009 | 09:21 PM
frank_el_tanke's Avatar
relatively simple process... remove the iacv located on the back of the intake manifold(has two bolts and two hoses), spray it with brake cleaner fluid to get all the gunk out. let dry or use a compressor to help dry it faster... then put it back in.
Old Dec 4, 2009 | 04:08 AM
josh7owens's Avatar
ok, I'm going to try that today. I really think its just a dirty ICV because it only does it when it up to opperation temp.
Joe Suttle
Jul 8, 2014 04:08 PM
MonkeyBoy7805
14
Jun 19, 2013 06:25 AM
323CRX702
May 5, 2012 02:22 PM
91_Mint_CRX
Apr 27, 2005 08:13 AM
