FL 1995 Jeep cherokee lifted, snorkel
am looking to trade or sell a 1995 jeep Cherokee. Here are the specs:
$1750 obo or trade for a civic or integra. must be 5-speed. or if you have something else just ask, worst i can say is no thanks.
I have a 1995 Jeep Cherokee 4dr, 5-speed (ax-15), 4wd (np231 t-case), 4.0 HO motor with 250,xxx miles.
-3" rough country lift with 2" Rustys spacers in front/shackles in rear with *new* 3.5" Rustys leaf packs
-Rustys steering box brace
-Rustys transfer case drop
-Rustys brake line extensions
-Rustys interior roll bar
-cut front/rear fenders
-custom snorkel
-custom roof rack with hi-lift jack and two KC lights
-electric fan
*new* starter
*new* alternator
*new* clutch/pressure place/throw out bearing
*new* slave cylander
*new* plugs, wires, coil and dizzy cap
*new* idler pully
*new* transfer case chain
*new* fuel pump/filter
*new* air filter
*new* u-joints in front drive shaft
*new* front brake pads and rotors
*new* tps
*new* O2 sensor
-17" pacer wheels wrapped in 265-70-17 Maxxis Buckshot's (spare tire is a new Cooper Discoverer STT 31-10.5-15)
-tow hitch w/ 2", 1-7/8", and d-ring will come with also have brand new
-no carpet or head liner
what it needs/will need:
-rear brakes need to be changed
-rear main is a little leaky
-front diff input seal needs replaced (which I have the new seal)
-both front tires will need to be changed soon
-needs an alignment
-little bit of a shake around 50
-needs new windsheild
-speed-o gear is broke
-3rd gear grind when shifting hard
-does smoke but only when it has been running a while and is an an idle it will also get a valve tick when driven for a while
any questions please text/call 607-857-1223... or e-mail race_fox2001@yahoo.com
will get pictures up soon
-custom snorkel
-electric fan
*new* starter
*new* alternator
*new* idler pully
*new* air filter
*new* tps
*new* O2 sensor
-needs an alignment
wayne-_-built
Apr 7, 2010 10:16 PM
